Stupid question here but please answere
Old Oct 9, 2009 | 08:19 PM
JOHNSN10's Avatar
JOHNSN10
Default Stupid question here but please answere
Im stuck with the stock 275/60/r20 tires for now on my ram (1500) and i have a question.
I just read online that i should be using 60 psi in the tires but ive been told not to use anymore than 34 psi per tire.
So what should i have in there for psi? Remember these are stock tires
Old Oct 9, 2009 | 08:23 PM
Jarrod904's Avatar
Jarrod904
look inside your door.. on the sticker it tells you.
Old Oct 9, 2009 | 08:24 PM
cheapbeater's Avatar
cheapbeater
stock tires should have 34 psi... whoever told you 60 is on crack...
Old Oct 9, 2009 | 10:08 PM
lxman1's Avatar
lxman1
Site Moderator
My 08 calls for 36psi front and rear in the door jam.
Old Oct 10, 2009 | 12:49 AM
HemiLonestar's Avatar
HemiLonestar
Hello! Look on the SIDE of the tire!
Old Oct 10, 2009 | 09:36 AM
sos's Avatar
sos
HemiLonestar, the number on the side of the tire is the MAXIMUM pressure the tire can handle. That is not what you should be inflating to though. Always go with the recommended pressure from the vehicle manufacturer, which is on the drivers door or pillar next to it.
(And I know you're probably being sarcastic, but some people might not understand that and take your post as true.)
Old Oct 10, 2009 | 09:46 AM
TRXHemi's Avatar
TRXHemi
60 psi??? Good Lawd!!
Old Oct 10, 2009 | 10:43 AM
ramhunter9's Avatar
ramhunter9
i run 5 psi more than recomended
Old Oct 10, 2009 | 04:00 PM
AF_HEMI's Avatar
AF_HEMI
i run 5 psi lower than that listed on side of tire... which is 55psi. the higher the pressure, the better mileage/tire wear. make sure the number doesnt exceed whats printed on the tire though
Old Oct 10, 2009 | 05:13 PM
Dubsport's Avatar
Dubsport
I agree... Tires last longer with the pressures a little higher than vehicle specs and closer to tire specs!
