Hemi engine swap! finally got it and starting swap, ill keep updating this as i go!
Good luck on the engine swap, you're most likely one of the only few guys in a 2002 who can boast a HEMI badge. (Because I'm not sure if there have been swaps in '02s before or not.)
There are emissions tests in Kansas? I've never had one since I've had my Dodge. The only thing was a VIN inspection when I bought the truck since it came from Missouri.
wow i wish we had it that easy, but the guy i usually have inspect it should be surprised to see a hemi under the hood now! but i should be fine, cuz its from the same generation that the hemi was introduced into the rams, and im running the same cat crossover y pipe that came stock until i get it inspected, then ill swap in the complete dual catless exhaust i have now on it, it was from summit and it sounded awesome, cant beat 3" duals!!
yeah im pretty sure i have never heard of one either from friends, co-workers, or online anywhere, im guessing the main reason is that the hemi wasnt introduced until late 03/early 04, so in the 02's everything has to be modified, from the wiring to the oil pan and so on, so its quite the task, but not impossible, just need the right know how and the right tools helps too!
And stated on this site, quite some time ago, you can swap your engine out for any engine later put in that vehicle, as production. So you can't put a 6.1 Hemi in, but you should have no problem with a 5.7. And if they tried to get after you for it, you said that your engine blew up, and it was more economical for you to go with the Hemi.
I actually believe the Hemi came out early 2003. My truck says that it was built 02/03 and my build sheet does show that it came with the Hemi.
no problem, but yeah the hemi im putting in it is in fact a 2005 hemi 5.7L from a durango, and i didnt know that the hemi was out in mid 03, nice to know i guess, thanks
ok im gonna second that reply about the 4.7L airbox, cuz well first off i dont have it anymore, but if i did and did in fact put it back on for an inspection, what would be the difference, cuz yes the vin and build sheet show it as being a 4.7, but one look at that engine from 100 feet away and i knew it was a hemi, so im sure a mechanic whos works on many every year would see it and know what it was, plus the emissions test would give up the secret under the hood too! guess im wondering where it was going with that idea?!
Other than that, it sounds like a fun project.... Good luck and Take as many pics as possible!!!!
