Leveling kit & Limit Straps!!?
Old Oct 22, 2009 | 11:57 AM
98cherryram's Avatar
98cherryram
My shocks are for 2-4 inches of lift and they are perfect, so if you only got 2 inch longer shocks total, then you didnt get enough.
ramhunter9's Avatar
ramhunter9
driver side has more weight ...you and a full gas tank . i dunno man i dont have the same suspension you have
Old Oct 22, 2009 | 12:35 PM
JRam_4.7's Avatar
JRam_4.7
Yeah I figured that on the weight, thanx for the help. Hopefully I can figuere this out.
I found this through Google, its from the 2nd Gen...I think he had the same problem and fixed it by adding limit straps.
https://dodgeforum.com/forum/2nd-gen...r-problem.html
I wonder if it would work for me, I guess I will try and see.
Will order the straps this weekend.
Old Oct 22, 2009 | 12:54 PM
cordaco's Avatar
cordaco
Originally Posted by pousaan
I hope you figure out your problem, but I just wanted to throw in a comment about my truck.
When I put my leveling kit on, I never changed my shocks at all. When I let the shock bolts go, with my truck supported on jack stands and my wheel fully extended to the ground, the shock kept on decompressing about 6" or more longer than what the tire was able to fully extend to the ground. I am after doing multiple trips offroad, over horrible terrain, and have no noises or problems at all. Therefore, I decided against putting on new shocks......I just didn't need them. Any comments?
Originally Posted by ramhunter9
you also have a 2500 like me we have bigger shocks and a taller stance that a 1500
You guys have 4X4 rams... You wont experience this problem.
It may be that your driver side shocks have been tightened tighter and are compresing the bushing more. Try a torque wrench or maybe stiffer or larger rubber bushings.
Old Oct 22, 2009 | 01:03 PM
JRam_4.7's Avatar
JRam_4.7
thanx, will take that into consideration.
Old Oct 22, 2009 | 03:27 PM
TRXHemi's Avatar
TRXHemi
I have a 2WD 2008 that I put a 2" kit on with longer Fabtech shocks. I only have the bump on the PASSENGER's side. And yes, it is the hitting the shock bucket on the way down. But I hardly notice it all now. If you hit a hard bump, you may hear it, but I hardly ever hear it. After speaking to Fat Bob's garage about it, they had no fix....
Old Oct 22, 2009 | 04:54 PM
ramhunter9's Avatar
ramhunter9
ahh yes now i see his is a 2wd sorry about that
Old Oct 22, 2009 | 05:10 PM
TexasRam01's Avatar
TexasRam01
You need to go back to your stock shocks. I am having the same trouble, as are many others on this forum with the leveling kits. I have done extensive research and have found that the dodge engineers designed our front suspension to have the shocks limit wheel travel (Keeping the upper arm from hitting the tower). By getting longer shocks, you are allowing more wheel travel. I have been told that you might also be able to go to a stiffer shock???? Am not sure how or why this works???? but am going to give it a shot this weekend... only takes 15-20 minutes to change the front shocks out... GOOD LUCK.
Old Oct 22, 2009 | 05:21 PM
explorer9950's Avatar
explorer9950
my truck does the exact same thing on the drivers side, I yet to have found a solution for it, but I put a 2.5 leveling kit on, mine is a 2007 2wd as well four door...so if you find a solution please message me and let me know what it is, I would greatly appreciate it....
Old Oct 22, 2009 | 05:55 PM
JRam_4.7's Avatar
JRam_4.7
Thanx guys fo the advice...& yes its a 2WD.
I guess I will try switching out the shocks back to the stock shocks later today...I will post the results in a couple of hours when I get back online.
If that doesn't work I will try the limit straps and keep you updated if I find the solution.
