Tow/Haul Mode
Old Oct 23, 2009 | 05:00 PM
dodgequad05's Avatar
dodgequad05
Default Tow/Haul Mode
My light doesn't come on when I push the tow/haul mode button. Need help figuring out how to make it work.
Old Oct 24, 2009 | 12:28 AM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a bad wire in the shifter or bad switch perhaps. Do the shift points not change when you try to turn it on?
Old Oct 26, 2009 | 10:17 AM
dodgequad05
When I push the switch I don't notice it shifting any differently then it was before I pushed the button. Is this controlled by a relay or fuse? When I key the key to "ON" I don't see a light on the instrument panel light up. Is it possible I don't have that option installed on the truck and I just have a button there for looks?
Old Oct 26, 2009 | 04:19 PM
agtiger's Avatar
agtiger
If driving ~45mph...you should see a slight jump in RPMs when activating the tow/haul mode.
Old Oct 26, 2009 | 05:53 PM
lxman1's Avatar
lxman1
Site Moderator
If it has the button, it should be there. Could be a broken wire in the shifter that is keeping it from actuating.
Old Oct 26, 2009 | 06:11 PM
dodgequad05
No the truck doesn't do anything when the button is pushed. Is there a relay or fuse that it attaches to?
Old Oct 26, 2009 | 07:23 PM
MikeHTally's Avatar
MikeHTally
Could be a relay or fuse. Check the fuse panel cover. Hopefully, it's not the switch.
Old Oct 27, 2009 | 10:59 AM
dodgequad05
I don't have the user manual. Do you know what fuse it would be or if there is a diagram on the back of the fuse panel. Also where is the fuse panel?
Old Oct 27, 2009 | 05:16 PM
lxman1's Avatar
lxman1
Site Moderator
The fuses are under the hood in a big black box. Usually near the battery. I don't know which fuse, if any, though.
Old Oct 27, 2009 | 06:26 PM
dodgequad05
It looks like the light for the Tow/Haul mode is in the center of the display cluster. It does not light up when the key is turned to "on" as well. So maybe a fuse is out since the light isn't coming on?
