tight budget tire question
Old 11-12-2009, 09:34 AM
bigpappaholt's Avatar
bigpappaholt
bigpappaholt is offline
Default tight budget tire question
im kinda on a tight budget and looking to get some tires to get me through the winter. i found a set of 17" online with 245/70/17 michelin tires with about 80 tread, or should i just replace 2 rear tires, buy one and take the unused one off the spare to put on rears for my stock 20's which are about done? are there any issues i would have with dropping down to these small 17's besides it looking funny? i have a super chip so i could change the speedo. heres pic of rims..
heres my truck...
Old 11-12-2009, 09:42 AM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
where are you located? Cuz those stock tires blow in the rain/snow. Certainly not made for winter anything. And i doubt those Michelins are any better?
Those tires you have there, what are the markings on them? Gotta look at the weight limits of the tires. I think they are too small personally. 245 is pretty narrow. Sure narrow does better, but check the weight requirements first. They need to be rated at 2,000lb minimum cuz your truck unloaded is 6,000lbs
You can replace all 4 for under $800 if buying all 4 new one's.
How much are you willing to spend? How much are those tires in the pic?
Any time I have looked at used tires and they are claimed to have 80% tread, they are more like half worn. people don't ahave tire depth guages and they certainly don't have new tires to compare against.
Old 11-12-2009, 09:53 AM
Horseapples's Avatar
Horseapples
Horseapples is offline
here is a set of Pirelli Scorpions, rated excellent or superior in every catagory. They are 134.00$ each from tire rack, thats 534.00$ for a full set
http://www.tirerack.com/tires/tires....wd&autoModClar=
Old 11-12-2009, 09:57 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Chk prices on ebay because I bought a brand new set of those 20" tires for about 300 bux.
Old 11-12-2009, 10:24 AM
bigpappaholt
the 17" rims and tires i could get for $175 for the set.. I live in Indiana so i do get snow. Im in college and money will be kinda tight till summer, (when i would like to get some 305/55/20" for the stock rims) so just looking for cheapest way to get me off the about burnt out rears. Im not sure about the 17" tire load rating... how do i find that.. here pic of tread i was sent.
Old 11-12-2009, 10:32 AM
bigpappaholt
deleted double post
Old 11-12-2009, 10:53 AM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
tires are a hard thing to buy used im always worried about it cause if it blows or is dry rotted you end up in a bind anyway....and it could be dangerous .....just things to think about.....personlly id buy new ones wether it rear now and front a few months from now or what have you but id go new.....i know money is tight trust me....
Old 11-12-2009, 01:30 PM
rcman0056's Avatar
rcman0056
rcman0056 is offline
Finally another college kid whose parents don't pay for their truck like myself.
I would go with two tires for the rear. The cheapest way is to get the tires yourself and bring just the tires and rims to be mounted. otherwise they charge you hourly to take the rim off the truck, take the old tire off, but the new on and then put it back on the truck.
Old 11-12-2009, 02:08 PM
chambers's Avatar
chambers
chambers is offline
Those michelins are what came stock on my 04 ST and they are rated at 2205 lbs. per tire, see here http://www.tirerack.com/tires/Spec.j...um%3D47R7LTXAS. They do suck in the rain and probably snow too, but I haven't driven on mine much in the snow. I don't see any issues if you get those and reprogram your speedo except that they won't give you good wet traction.
Old 11-12-2009, 02:41 PM
truckin151's Avatar
truckin151
truckin151 is offline
The thing I dont like about tirerack is the extra fees. The tires are a lot cheaper but every place I have checked that is suppose to be a dealer to do the mounting all want to charge $25 per tire to mount them, $10 for balancing, and $5 per valve stem so in the end a cheap tire is about the same as one from discount. My tires are getting pretty worn right now and need to changed soon but two tires is gonna be about $410. Im thinking sisnce I have the $40 warranty from discount I may have to run over a few bolts to have them replaced under warranty... I know kinda bad way to do it but if I do two tires like that and pay out right for 2 thats still a sh*t load of cash for the tires.
Quick Reply: tight budget tire question
