Rust!!
Old 11-22-2009, 08:54 PM
Rotdog98's Avatar
Rotdog98
Rotdog98 is offline
Unhappy Rust!!
Well between my friends they have an 07,04,02,and 98 rams and mine is the only one rusting where the tail gate meets the bed you can't see it when the tailgate is up so I might just fix it myself was going to take it to the dealer and make sure it's not under my warranty first. Just sucks cause that was something I didn't think I would have to worry about for about 10 years unlike the 83 Ramcharger I traded in on it.
Old 11-22-2009, 09:33 PM
all of 75's Avatar
all of 75
all of 75 is offline
Hmmm. That's surprising. Do you live in a damp area? Do you not wax that area?
Old 11-22-2009, 10:28 PM
Rotdog98's Avatar
Rotdog98
Rotdog98 is offline
I live in MO I have waxed it in the past maybe when it was built that part of the truck was not E-coated properly
Old 11-22-2009, 10:31 PM
nim81's Avatar
nim81
nim81 is offline
i too live in missouri and had a lil bit of rusting on my bottom inside lip of tailgate and lower back end of bed.. i sanded everything down and used rustoleum roll on bedliner on the inside tailgate and bed.
Old 11-23-2009, 04:38 PM
02Regcab's Avatar
02Regcab
02Regcab is offline
I live in Canada with the stupid salt on the roads in the winter,,
My bed started doing this too late last year and by this time its already
spread to be visible on the outside of the bed now .. Its only a matter of
time before the rust cancer eats my whole truck
Old 11-23-2009, 04:55 PM
big guy's Avatar
big guy
big guy is offline
I oil spray mine every year. So far so good!
Old 11-23-2009, 05:04 PM
Markmm0000's Avatar
Markmm0000
Markmm0000 is offline
open up your hood and look at the seam on the inside of the hood. you might be in for a surprise. My truck has almost no rust on it but its rotting right there already.
Old 11-23-2009, 05:09 PM
oefootball_70's Avatar
oefootball_70
oefootball_70 is offline
Im in Kansas City, KS we are close. I have rust on the under side of my truck. Not on that part.
Old 11-24-2009, 09:45 PM
Unperfected's Avatar
Unperfected
Unperfected is offline
i have some rust there i sand blasted it and rust painted it the used dodge undercoat on it. mines an 06 with like 50 th kilometers
Old 11-24-2009, 10:11 PM
hemiguy0302's Avatar
hemiguy0302
hemiguy0302 is offline
I too live in the great white north and the pinch seams below the rockers and at the bottom of the tailgate started to rust last year. I bought some duplicolor that matched the truck perfectly sanded down the the rusty areas first with some 100 grit then went over it with some scotch brite gave it a quick blast of primer (after masking the desired areas off I should add) then giving the panels a splash of 2 coats of paint. It has been holding up well as it has lasted a weekend already but the tailgate is starting again not too concerned though its getting painted and dent popped come spring.
Quick Reply: Rust!!
