Indexing Plugs
Old Dec 4, 2009 | 11:45 PM
BigSwede's Avatar
BigSwede
Default Indexing Plugs
Will be changing my plugs for the first time soon. I've read about indexing the plugs so the ground electrodes face the center of the cylinder. How do you accomplish this without either over or under tightening the plugs? Are there washers to use? Help is appreciated.
Sadly, I am way over due.........59k on my '07 and this is my first plug change. She's been running so good I didn't bother.
Have a good one.
Old Dec 5, 2009 | 12:03 AM
AF_HEMI's Avatar
AF_HEMI
i've never heard of indexing the plugs like that. as far as my knowledge goes, you're MUCH better off following the suggested torque settings (23 lb ft if im not mistaken without looking it up) than you are trying to get the electrodes facing center. Washers would also mess it up since the plugs are an exact length.
Not sure what plugs you're planning on using, but the Hemi actually likes the OEM champion copper plugs the best. Dont buy in to all the advertising crap other plugs have...they wont work nearly as well.
Old Dec 5, 2009 | 12:09 AM
dodgetrucker75's Avatar
dodgetrucker75
indexing is trial and error, mark them, tighten them and see where they are at, if ther not right, try another plug, but i think the trouble far out ways the benifits in a street motor
Old Dec 5, 2009 | 01:32 AM
lxman1's Avatar
lxman1
Site Moderator
Very hard to do since the plug is do far down in the head it will be hard to see the plug when installed to see it's position. Since there are 2 plugs per cylinder, I wouldn't waste my time. This is more for wedge headed engines.
Old Dec 5, 2009 | 01:58 AM
Dodge.Ismo's Avatar
Dodge.Ismo
Mark your spark plugs with a marker on the side which faces the open end at your spark electrode. Get hold of a an area speed shop or where ever you can get a hold of the proper spark plug indexing type washers, (they come in a few different thicknesses to help accomodate with your plug alignment). It IS a trial and error situation..you'll be turning them in and out all day to get them right, (quickest way is having your heads out of vehicle). It does work...but for normal street use,...the fuel savings and power gains may not be worth all the effort...good luck though.
Old Dec 5, 2009 | 06:06 AM
abarmby's Avatar
abarmby
IMHO don't bother.
This is an old "racers" trick, to eek out the last 1-2 hp out of a race motor.
You wouldn't see any difference on the street and with 16 to do, it's a complete waste of time.
Al.
Old Dec 5, 2009 | 08:34 AM
Gone Fishin's Avatar
Gone Fishin
Don't waste your time or energy. You won't see a dimes worth of power or economy from it. On the other hand, you may have the reward of a few bloody knuckles from trying to get them to the proper location. You're better off worrying about changing them at the right interval to keep you're gas mileage and running performance up.
These engines ARE sensitive to upkeep. I have no doubt that you will notice a difference after their changed. Make sure you keep the plug wires in their original tracks as crossfiring can raise issues.
Old Dec 5, 2009 | 11:18 AM
BigSwede's Avatar
BigSwede
thanks for the info. I'll forgo indexing them when I put them in. I'll be using the champions. Only mod to the truck is airraid CAI. I feel bad that she's been neglected. Sadly, she takes a back seat on maintenance since I am usually focused on cleaning/maintaining my bikes.
I appreciate the help
Old Dec 5, 2009 | 12:27 PM
dirtydog's Avatar
dirtydog
Moderate User
You should check the gap of the plugs rather than pulling them out of the box and stuffing them in. Use a wire gapper and not the slider type.
Old Dec 5, 2009 | 04:00 PM
HemiLonestar's Avatar
HemiLonestar
Not worth it for a street engine, especially trying to do it with twice the normal amount of plugs...
