New Muffler Ideas
Old 12-05-2009, 02:35 PM
02Steve1990's Avatar
02Steve1990
02Steve1990 is offline
If I had this done by a shop, because I am limited with cutting tools, they won't have to wire anything up will they?
  #42
Old 12-05-2009, 02:37 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Off_Road_Teacher is offline
Originally Posted by 02Steve1990
If I had this done by a shop, because I am limited with cuttin tools, they won't have to wire anything up will they?
All you need is a hack saw to cut. You don't need to weld it up, you could always clamp it. Then you wouldn't need a shop to do it for you. I am wishing that I didn't weld mine now that I am pulling out all the piping when I put my headers on.
  #43
Old 12-05-2009, 02:47 PM
02Steve1990
Silver, do you need to clean it every now and then, i thought I read something somewhere about cleaning it will some kind of cloth?
  #44
Old 12-05-2009, 03:09 PM
02Steve1990
Just not sure how I'll get the wiring into the cab to place the controle module somewhere (most likely in the center console since there is a power supply in there).
  #45
Old 12-05-2009, 03:23 PM
Off_Road_Teacher
There are plastic plugs in the fire wall that you can drill through and feed wiring through.
  #46
Old 12-05-2009, 03:26 PM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
All my wiring is under the hood. I connected it to the battery. I read that u should clean dmh one every once in a while with steel wool
  #47
02Steve1990
You don't happen to have any pics do you?
  #48
Old 12-05-2009, 03:28 PM
Off_Road_Teacher
I don't have any on hand but I could try to get one for you. Since it is under the dash it might not turn out, but I can try...........after it stops snowing here
  #49
Old 12-05-2009, 03:33 PM
02Steve1990
Thank you, sir
  #50
Old 12-05-2009, 04:07 PM
02Steve1990
Originally Posted by SilverBullet08
http://www.racelandus.com/p-68-racel...-remote-3.aspx
u might need the smaller piping one since u have a 4.7 but i would check to make sure. that one is only 78
you got that one for 78? It's 98 now?
Quick Reply: New Muffler Ideas
