3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
You might have to use a knife scrapper if the tint is been there for to long
You'l always have to use a scraper even if the tint is new. Most tint will peel off by hand and then the razorblade is to scrape the adhesive glue off.
Starting in the corner is easiest. I can strip 2 front windows and have them sparkling in under 10 minutes.
Use a heat gun if you have one to get the tint kinda bubbly and ready to come off.. With that and a razor blade scraper I did 2 front windown on my gfs car in a couple minutes..
How long has it been on there? I removed some tint that was peeling from my old Integra when I bought it, had been on there 5 or so years. For the nightmare I went through to get that stuff off $40 is a bargain.
its only been on for 6 months, $40 may be worth it
Heat gun is not needed unless your not strong enough to peel the film off without.
Makes a mess IMO. Peeling off cold is best.
