Old Aug 10, 2015, 03:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Fog light install (new member)
Old Jan 3, 2010 | 12:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by fk1022
ya very lucky, not only did they work but also stay on with the brights.
Yeah. US settings won't allow that. the ecu must be set to another Country region for the fogs to work with the brights.
Old Jan 3, 2010 | 03:08 PM
lxman1's Avatar
lxman1
Site Moderator
Truck must have been smuggled in from overseas
Old Jan 3, 2010 | 03:10 PM
wyseguy77's Avatar
wyseguy77
i just installed fog lights on mine and i got them off ebay for 120. it came with the factory wires, switch, and all the parts for the fog lights. the switch took the longest to install but mine worked after hooking it all up, even stay on when my brights are on. but if you want to hook them to thier own switch i don't see why you can't use the factory wires to do so.
I did the same thing. My kit is a Mopar kit came with everything I needed, thought I'd have to take it in and get it programmed but to my surprise they turned right on. And they work with the brights.
Old Jan 3, 2010 | 04:14 PM
fk1022's Avatar
fk1022
very lucky too
Old Jan 4, 2010 | 07:25 AM
GJF1216's Avatar
GJF1216
After purchasing the OEM kit on eBay, I still decided to stay with the wiring I did myself. The switch that came with my kit called for drilling a hole in my dash. I thought I would be getting the switch that replaces my old one. Anyway, I decided to use my own switch and wiring that keeps it independent and stays on with the brights. But my 08 is also rigged for wiring of fog lights. Wiered how some trucks are and others aren't. If I decided to use factory switch, would all I have to do is plug it in under the dash?
Old Jan 4, 2010 | 08:18 AM
fk1022's Avatar
fk1022
ya the same switch goes in the same spot and uses the same wires, it just replaces the one you have now
Old Jan 4, 2010 | 09:38 AM
RubberFrog's Avatar
RubberFrog
If you had to drill a hole in the dash, then you didn't get an oem kit. You probably got oem lights and some hack wiring and a generic switch.
Old Jan 4, 2010 | 10:24 AM
dirtydog's Avatar
dirtydog
Moderate User
There could be wiring already there. I have had previous vehicles with wiring there and no fogs. Same with my under hood light that I don't have. Thanks Chrysler for keeping my MSRP sticker down another $30 to not have an underhood light...Jerks...lol
Anyways, i have an underhood light plug just waiting for a light to be installed.
Must have something to do with packages and trim styles that decipher which trucks get pre-wired and such????
As far as the seperate switch. this means your runing seperate power than the factory switch and of course the lights will work.
Old Jan 5, 2010 | 01:01 PM
GJF1216's Avatar
GJF1216
Thanks for the input. And yes they are ran seperately to the battery.
So if I got an OEM switch rubbecfrog and replaced my switch and just plugged my lights into the existing wires they may work like some models do?
And come to think of it, I have to check if I have that under the Hood light. Man that would be some bull****. Your saying you have the wiring there but no light ?
Old Jan 5, 2010 | 01:07 PM
RubberFrog's Avatar
RubberFrog
They should. It seems to be hit or miss as to whether or not the programing is there.
