recon white lightning led strip???
Old Dec 26, 2009 | 04:40 PM
Hemi-5.7's Avatar
Hemi-5.7
Default recon white lightning led strip???
i just finished installing the white lightning tailgate led stip. I used the 4 prong trailer connector to hook it up. every thing works (running lights,brake lights,turn signals) except the white reverse led lights. There is a white wire coming off the led strip that i think is for hard wiring. I thought you could just use the trailer light connector for all the applications. Am i wrong? if i need to hard wire, how to i do so?
thanks
Old Dec 26, 2009 | 05:04 PM
EJM05's Avatar
EJM05
You need to hard wire the reverse light.
Old Dec 26, 2009 | 05:46 PM
Hemi-5.7's Avatar
Hemi-5.7
thanks, any tips on how to hard wire this thing?
Old Dec 26, 2009 | 05:53 PM
EJM05's Avatar
EJM05
I've had no experience with hardwiring things but from what i've read just tap it into the reverse light coming from the tail light. So all you have to do is find out the right wire to tap it into and I'm sure its the one connecting to the reverse bulb. But I'm not sure how hard it is to do. Good Luck and get some pics up when your finished.
Old Dec 26, 2009 | 07:26 PM
Hemi-5.7's Avatar
Hemi-5.7
thanks EJM, ill get some pics up wen its all done
Old Dec 26, 2009 | 08:02 PM
explorer9950's Avatar
explorer9950
yep, just splice open your reverse wire, wire that bad boy into it, make it nice and neat and your good to go!! Post pics when done!!
Old Dec 26, 2009 | 08:07 PM
SMKNRAM's Avatar
SMKNRAM
use the quick connect splice that you put both wires in and squeeze with pliers. you may need a tester to make sure you have the hot wire going to your back up light. post pics
Old Dec 26, 2009 | 09:38 PM
sad_drake's Avatar
sad_drake
mine came with instructions on connecting it and a t-splice to do so i just ran the wire up through the fender well and tapped into it so it doesnt show
Old Dec 27, 2009 | 01:10 AM
AWE Daniel's Avatar
AWE Daniel
Its really easy, what i did with mine was put my parking brake on and put the truck in reverse. Then i just touched part of the wire to each connection on the tail light plug. Once i found which one it was I just quick spliced into that. My light bar has the turn signals that chase each other so after it was all wired up I unplugged the trailer harness part and left it unplugged for a little bit and once it plugged back in it relearned the chase speed. But if your bar doesnt chase like that there is no need. Realy easy though.
Old Dec 27, 2009 | 10:09 AM
hemiraptor700's Avatar
hemiraptor700
It is the white wire with the green stripe coming straight from the harness in ur taillight, I used a heat shrink butt connector cause they won't corrode as easily as a scotch lock, aka the 2 wire to 1 wire jig
