5w-20 vs 5w-30 debate
Old Feb 4, 2010 | 02:44 PM
slowen's Avatar
slowen
Default 5w-20 vs 5w-30 debate
I have a 07' 3.7L, it calls for 5w-20, but a lot of websites out there say that weight is garbage for your engine life, what is everybody's opinion?
Old Feb 4, 2010 | 02:47 PM
Tizzy1's Avatar
Tizzy1
if it doesn't have variable valve timing, use what you want. The others need the thinner oil.
Old Feb 4, 2010 | 03:10 PM
slowen's Avatar
slowen
Hmm I'm pretty sure it does.
Old Feb 4, 2010 | 03:41 PM
chambers's Avatar
chambers
It protects the engine fine, and if it's what dodge specs then you should use it if you care about your warranty. If you want to get an oil analysis to check your engine wear you can get a free test kit from blackstone labs. Send a sample of your used oil to them and they will analyze it for $22.50, although I really don't think you need to.
Old Feb 4, 2010 | 04:29 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
use the 5w20
Old Feb 4, 2010 | 04:42 PM
Ben D.'s Avatar
Ben D.
honda has been using this weight for a long long long time pretty much from 2000 ish up and look at how long those motors last. Unless some idiot riceboy is doin the mega rev to infinite rpm's all day lol
Old Feb 4, 2010 | 05:15 PM
RubberFrog's Avatar
RubberFrog
I don't have any inside info on oil, but I look at it this way- why trust some random clowns on a website when dodge's engineers specifically spec'd out 5w20 as the proper lubricant for your motor?
Old Feb 4, 2010 | 09:08 PM
HemiLonestar's Avatar
HemiLonestar
3.7 was suffering from sludge build up like it's big brother the 4.7 was. They figured out the 5W-20 reduced the sludge, which was great since the MDS hemi needs it for the solenoids to work properly. In 2007 they recommended 5W-20 across the board. As of 2006 FSM still called for 5W-30 (as did the oil cap on the engine itself).
Old Feb 4, 2010 | 09:20 PM
ramhunter9's Avatar
ramhunter9
never been said so well
Old Feb 4, 2010 | 09:37 PM
MikeHTally's Avatar
MikeHTally
Variable valve timing? Might want to look further -- I don't think so. MDS yes, VVT, no.
