Desperate and broken down in Florida
Old Feb 12, 2010 | 07:37 PM
Kevno6's Avatar
Kevno6
Default Desperate and broken down in Florida
Left Jersey in the morning for Florida and happened to break down in Jacksonville. Blew my radiator and got the parts but Dark, windy and raining and I don't have a manual to do the job. Does anyone have the DRM03pdf file Ram Manual in there possesion that was floating around a few yrs back. Desperate and cold, sleeping in the Ram. Thank You
Old Feb 12, 2010 | 07:51 PM
cwboyjohnny24's Avatar
cwboyjohnny24
RADIATOR-3.7L/4.7L/5.7L
REMOVAL
(1) Disconnect battery negative cables.
WARNING: DO NOT REMOVE THE CYLINDER
BLOCK DRAIN PLUGS OR LOOSEN THE RADIATOR
DRAINCOCK WITH THE SYSTEM HOT AND UNDER
PRESSURE. SERIOUS BURNS FROM THE COOLANT
CAN OCCUR.
(2) Drain the cooling system (Refer to 7 - COOLING
- STANDARD PROCEDURE).
WARNING: CONSTANT TENSION HOSE CLAMPS
ARE USED ON MOST COOLING SYSTEM HOSES.
WHEN REMOVING OR INSTALLING, USE ONLY
TOOLS DESIGNED FOR SERVICING THIS TYPE OF
CLAMP. ALWAYS WEAR SAFETY GLASSES WHEN
SERVICING CONSTANT TENSION CLAMPS.
CAUTION: A number or letter is stamped into the
tongue of constant tension clamps. If replacement
is necessary, use only an original equipment clamp
with a matching number or letter and the correct
width.
(3) Remove the hose clamps and hoses from radiator.
(4) Remove the coolant reserve/overflow tank hose
from the radiator filler neck.
(5) Remove the coolant reserve/overflow tank from
the fan shroud (pull straight up). The tank slips into
slots on the fan shroud.
(6) Unclip the power steering hoses from the fan
shroud.
(7) Disconnect the electrical connectors at the
windshield washer reservoir tank and remove the
tank.
(8) Remove the fan shroud mounting bolts and pull
up and out of the radiator tank clips (Fig. 36). Position
shroud rearward over the fan blades towards
engine.
(9) Disconnect the transmission cooler lines from
the transmission cooler, then plug the transmission
lines and cooler to prevent leakage.
(10) Disconnect the power steering lines from the
power steering cooler, then plug the power steering
Fig. 36 Fan Shroud - Gas Engine
1 - RADIATOR
2 - SCREWS
3 - FAN SHROUD
4 - SLIDE MOUNT
7 - 54 ENGINE DR
(11) Remove the two radiator upper mounting
bolts (Fig. 37).
(12) Lift the radiator straight up and out of the
engine compartment. Take care not to damage cooling
fins or tubes on the radiator and oil coolers when
removing.
NOTE: The radiator is equipped with one alignment
dowel on the bottom of the outlet tank and one
retaining bracket on the front side of the inlet tank.
Both features have rubber insulators attached to
them that must be present. The alignment dowel fits
into a hole at the bottom of the front end sheet
metal vertical support post and the support bracket
rests on top of the lower radiator closure tube.
INSTALLATION
(1) Position the fan shroud over the fan blades
rearward towards engine.
(2) Install the rubber insulators to the lower radiator
mounting features (alignment dowel and support
bracket at the lower part of the radiator).
(3) Lower the radiator into position while guiding
the alignment dowel into the vertical post bracket.
Position and seat the lower radiator support bracket
onto the lower radiator closure tube.
(4) Install the upper radiator mounting bolts.
Tighten bolts to 10 N·m (90 in. lbs.).
(5) Connect the lower radiator hose and install the
clamp in the proper position.
(6) Connect the power steering hoses to the power
steering oil cooler and install the clamps.
(7) Connect the transmission oil cooler lines to the
transmission oil cooler and install the secondary
latches.
(8) Position the fan shroud into the mounting clips
on the radiator tanks and secure with bolts. Tighten
the bolts to 8.5 N·m (75 in. lbs.).
(9) Secure the power steering hoses into the clip
on the lower fan shroud.
(10) Install the windshield washer reservoir tank
and connect the hose and electrical connector.
(11) Install coolant reserve/overflow container
hose(s) to radiator filler neck and secure properly
with clamps.
(12) Install coolant reserve/overflow container or
degas container to fan shroud and tighten the bolts
(13) Connect upper radiator hose and install
clamp.
(14) Install battery negative cable.
(15) Fill cooling system with coolant (Refer to 7 -
COOLING - STANDARD PROCEDURE).
(16) Operate the engine until it reaches normal
operating temperature. Check cooling system fluid
levels.
Fig. 37 Radiator
1 - SCREW
2 - SCREW
3 - LOWER MOUNT
4 - RADIATOR
5 - DRAINCOCK
6 -LOWER MOUNT
Old Feb 12, 2010 | 07:53 PM
RedTruck-VA's Avatar
RedTruck-VA
Default Manual
Pm me your email address and I'll try to send you a copy of my 03 PDF manual.
Old Feb 12, 2010 | 07:56 PM
Kevno6's Avatar
Kevno6
Thank You very much, too freakin cold out so we willl be sleeping in truck tonight.
Old Feb 12, 2010 | 07:57 PM
Kevno6's Avatar
Kevno6
kevstonehouse@optonline.net
Old Feb 12, 2010 | 08:01 PM
cwboyjohnny24
Man, if you were in Orlando I'd put you up for the night. I'm sorry man. I hope you got the info I tried to post or even VA's pda. I feel bad for you brother.
Old Feb 12, 2010 | 08:05 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
No **** dude, ain't much I can do up here, but just hope for the best for ya. Good luck bro........
Old Feb 12, 2010 | 10:14 PM
HemiLonestar's Avatar
HemiLonestar
PM sent, if I was still stationed down there you'd be on your way already...
Old Feb 12, 2010 | 10:19 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
**** if you were within 50 miles of me I'd be there with a pop up canopy and floodlights.
how did the radiator go out? you're sure there aren't other problems? last thing any of us want is for you to change it all and realize you didn't solve the problem.
Old Feb 13, 2010 | 03:04 PM
Kevno6's Avatar
Kevno6
UP in running in 3hrs, what a freakin night. Only tool I didn't bring with me was a pliers for hose clamps but low and behold I offered and got a pair for $20 bucks off a guy driving by. These thing are getting gold plated and framed. Gotta do what ya gotta do. I offered him 10 but I only had a 20. Thank for jumping on this post with the help when I really needed it. THANKS GUYS
