Going with wheel spacers.... wheel question
#24
ok go to the second page of this thread and look at the pictures, the picture of the first spacers will bend ur lugs because it puts the pressure of ur rim and tire on the end of the bolt, so if u where to hit a pot hole or what real hard it would bend it, with the second ones in the second pic, where they bolts on to your original lugs and have new lugs for your rim, then u dont have to worry, its just the first ones make your rim move out on the bolt where it aint as strong and will bend, hope that answered your question big body
#25
In theory yes, but those lugs are plenty strong enough. Lots of guys have run and are running 1/4" spacers with no issue's at all. Have you had a personal experience where you lugs bent or are you just passing information from hear say?
and HOSS, the 2nd one's pictured are NOT necissarily Hub centric. They make both and Hub centric one's are more expensive and much harder to find. Hub centric is where the inside of the spacer opening fits over your hub ledge perfectly. This aligns the spacer to be dead centoer on the hub PLUS on the outer edge of the spacer, there should be a little edged lip that the wheel can set over and be perfectly centered. The thicker ones pictured ARE NOT hubcentric FYI...
#26
my 1.5" spacers did not cover my lugs, i would have had to get 2" to cover my lugs completly. luckly my rims have holes where the lugs stick out so i didnt have to cut the stock lugs down due to them sticking out past the mounting surface of the spacer.
#28
#29
Nah, didn't say you specifically said they were hub centric. If you go back through you will see how RamRango assumed they were hubcentic and then OE replied "fo sho", so i didn't want you to get confused about the truth of the situation and i don't think OE was speaking about that in particular anyways?
As for the driving around town is only good. This is very subjective from one person to the next and the same when your talking about spacers in general. Many guys will tell you don't go offroad with wheel spacers period.
I would much rather have 1/4" spacers than 1.5" spacers. The wider the spacer the more pressure you put on the hub bearings kinda like you were saying about the lugs, however; the wider spacers will put more stress on the hubs than the thinner spacers would on the lugs....if you follow?
Just some food for thought.
#30
its hard to see but they stick out pretty good.
