rotors
Old Jun 26, 2011 | 02:49 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by HemiHound
Why does Dodge have so much trouble with brake parts?I have a 94 Chevy truck and brakes is no biggy on it.What did engineers do wrong?
It's hit and miss with all of them I think. I've had four Grand Cherokees since '95, three of them were the ex's daily drivers and the '95 was fine, the '98 and '02 both ate rotors. My '02 GC Overland still has the originals at 98k miles.
My '98 Ram RCSB 4x4 ate it's first set of fronts at 30k miles, but my '04 is still on the stock ones (and stock pads) at 50k.
My little brother's '98 Chevy Z71 goes thru almost a set a year...
Old Jun 26, 2011 | 03:26 PM
IOVMatrix's Avatar
IOVMatrix
Ive gone through a couple sets of front rotors but I can tell you in MY case the problem is the driver lol.
Old Jun 26, 2011 | 08:05 PM
me0418840987's Avatar
me0418840987
It must be a here and there problem, because I still have one original rotor on the left side at 168,000 miles. It is scored all to hell, but still isn't warped. Never had it turned, because it is rusted tight, figure I'll change it when the bearing goes bad. I have the right side rotor sitting on top of the toolbox, all turned and ready to go in case I ever need it. I had to buy a new rotor when I changed the front wheelbearing because after you beat on the old one with a hammer, on Sunday, to get it off of the truck, no one is open that can turn them, but Advance is open late to buy a new one.
Old Jun 26, 2011 | 08:45 PM
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by chambers
07 w/ 30k on it and that's not under warranty?
Brakes and clutches are not covered under warranty. You can usually get support up to 12mon/12K.
I do not like cross drilled rotors, especially on a heavy truck. The holes tend to be a good point to crack. I prefer slotted rotors as they are not prone to cracking.
Old Jun 26, 2011 | 09:49 PM
JPlaisted's Avatar
JPlaisted
My stock ones broke..on the back side they just broke apart...thankfully it wasn't while I was going too fast..
Old Jun 26, 2011 | 10:48 PM
HammerZ71's Avatar
HammerZ71
I put Powerslots on my 2nd Gen with Hawk pads, stopped the truck even when towing the bass boat better than the stockers did when not towing. Going to the same combo whenever the stockers go on the '04, not in any hurry though, LOL...
Old Jun 27, 2011 | 06:43 PM
HemiHound's Avatar
HemiHound
Default Rotors and Shocks
Well i am out rotors,pads and shocks.....STILL VIBRATING ITS BUTT OFF.Is there any way to test calipers or do you throw the dice?Wife will not drive it,its soooo bad.We just bought the truck with 127,000 miles or so and inherited all this
Old Jun 27, 2011 | 08:10 PM
lxman1's Avatar
lxman1
Site Moderator
This vibration only happens when braking? Perhaps the ABS is going haywire.
Old Jun 28, 2011 | 05:39 PM
HemiHound's Avatar
HemiHound
How can i tell?ABS or Calipers?Any way to test either one?
