Please Help~! Engine knock after oil change
Old Mar 15, 2010 | 10:06 PM
rocket23's Avatar
rocket23
sounds like hemi tick too me!!
Old Mar 16, 2010 | 12:42 AM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
+1 on the hemi tick
knock would increase under engine load
your fine, just watch your gauges and oil level extra close for a couple days
Old Mar 16, 2010 | 03:37 AM
RedTruck-VA's Avatar
RedTruck-VA
Rod knock bangs when you let off the gas. Mains usually can be heard when the engine is cold and the oil pressure is usually lower than normal. Pounding rod might last thirty miles and then lets go. I think you have the hemi tick, but I would change the filter. I use nothing but Mobil 1 since shortly after break in. It is not the oil, but could still be a bad filter. Good luck...
Old Mar 16, 2010 | 07:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had rod knock once and it is something you dont forget.
Old Mar 16, 2010 | 09:08 AM
RedTruck-VA
Oh yeah, over the years I have lost a few engines. Had a flathead let go going through the traps at around 95 mph that tore up my floorboards and broke my windshield. I think it even cut up my tires running over the all the shapnel. lol
Old Mar 16, 2010 | 11:55 AM
I DRIVE A HEMI RAM DAMNIT!'s Avatar
the dealership said that it sounded like an exhaust valve closing and reverberating back through the exhaust..thats bull ****. I dont know what to do. Whats the hemi tick sound like..? like i said this is a slight tap or knock sound I would say..I just dont know what to do. I just ordered all my mods and now im short on money to have a motor torn down ... Ive been searching hemi tick..does somebody have a good video of it? I cant seem to find any. Like I said,mine isnt a tick really.. anyhow,another dealership said it sounds like a normal hemi but I think he is deaf~! i hear the coils clicking and ticking and what not,but this is lower. Anyhow,leads me to my next question,how much for a performance rebuild,or even a stock rebuild?
Old Mar 16, 2010 | 03:41 PM
dublduty's Avatar
dublduty
Wow dude, your jumping the gun. I am almost certain it is the infamous Hemi tick and like the others said using conventional oil quieted it down. It was already there but you just couldn't hear it and once a thinner synthetic was used it appeared. Almost sounds like an exhaust leak or the sound is coming from the oil pan. Just a slight knock but almost a tick and goes away when you give it the slightest bit of gas. Good luck and welcome to the Hemi tickin' club!
Old Mar 16, 2010 | 04:30 PM
josemer09's Avatar
josemer09
i found this vid on youtube maybe you can compare
this is what my hemi tick sounds like
http://www.youtube.com/watch?v=ntE55pVpU5Y
this one is a little loud
http://www.youtube.com/watch?v=Al5IE1bX0kw
Old Mar 16, 2010 | 07:13 PM
RedTruck-VA
Like most here I'm pretty sure you have the hemi tick. Mine sometimes has it and other times it doesn't. When I do hear it it is usually when I am along a wall or in the garage. I don't like it and don't really know what causes it, but I also don't worry about anymore. Good luck
Old Mar 16, 2010 | 07:34 PM
dublduty's Avatar
dublduty
Man that second video is crazy!!! I just hope mine doesn't turn into that.
