how wide is my rim?
Old Mar 22, 2010 | 12:25 AM
hoss67's Avatar
hoss67
Default how wide is my rim?
so i heard my rim is difference widths? so i am gonna see if you guys know for a Fact how wide my stock 17 inch rims are
Old Mar 22, 2010 | 12:29 AM
dmull013's Avatar
dmull013
They are 17"x8".
Old Mar 22, 2010 | 12:31 AM
rocket23's Avatar
rocket23
those are good tires for that size rim bud.
Old Mar 22, 2010 | 12:33 AM
hoss67's Avatar
hoss67
well i am installin a 2.5 inch leveling kit and gonna run 305/70/17's what u think? good rim size?
Old Mar 22, 2010 | 12:34 AM
98cherryram's Avatar
98cherryram
Go on the website of whatever tires you are buying and look at the specs on the tire and it will tell you if an 8 inch wide tire is recommended or if its in the risk zone
Old Mar 22, 2010 | 12:38 AM
98cherryram
a 295/70/17 smallest rim size recommended is 8 inches wide, so a 305 might be safe, but just barely... dont do anything real intense on that tire... lol
Old Mar 22, 2010 | 12:52 AM
04_ramslt's Avatar
04_ramslt
You'd be putting a 12in. wide tire on an 8in wide rim. So more than likely your gonna get premature wear on your tires.
Old Mar 22, 2010 | 12:54 AM
JoeHemi's Avatar
JoeHemi
Originally Posted by dmull013
They are 17"x8".
Yep what he said. "5-hole disk 17x8.0"
This is my source <<<< link works best with internet explorer.
Old Mar 22, 2010 | 01:32 AM
kx250frider617's Avatar
kx250frider617
i got the nitto 305/70/17 and they are a perfect size tire. my wheels are 17x9 though but i think your still in the range.
Old Mar 22, 2010 | 10:32 AM
beecherr345's Avatar
beecherr345
just dont run high psi in them and they will wear just fine. the rule of thumb for width of tire to wheel is a difference of 4. 12-8=4 so you still in the range. your good. do a chalk test to check the tire pressure is correct and then just remember that number.
