panel removal question, sub install
Old 03-25-2010, 12:59 AM
BlakeCP29's Avatar
BlakeCP29
BlakeCP29 is offline
what truck power wires should i watch out for?
  #22
Old 03-25-2010, 01:17 AM
BlakeCP29's Avatar
BlakeCP29
didnt mean post this and dont know how to delete the whole post
  #23
Old 03-25-2010, 05:46 PM
Matt99's Avatar
Matt99
Matt99 is offline
Just watch where you are running your wires, try not to run the wires near any other wires if you dont have to
  #24
Old 03-25-2010, 06:27 PM
BlakeCP29's Avatar
BlakeCP29
so would my best bet be putting the amp behind the seats or under the front seat? i just dont want overheating to be an issue behind the seats
  #25
Old 03-25-2010, 06:39 PM
Matt99's Avatar
Matt99
Matt99 is offline
you would be alright. And if you were worried, tie in a little computer fan by the amp.
I would do the back wall...when i get some time, im moving mine from under the seat to the back wall
  #26
Old 03-25-2010, 07:15 PM
Albertaramfan's Avatar
Albertaramfan
Albertaramfan is offline
After reading the post I felt I should add that decks have remote wires because amps are not meant to be turned on by a 12 volt power supply. Hence why even the best decks have at most an 8 volt preout...
You will run risk of prematurely killing your amplifier. Wiring off the cigarette lighter will work but will diminish the life of your amplifier.
  #27
Old 03-25-2010, 07:23 PM
OICUDRIVE12's Avatar
OICUDRIVE12
OICUDRIVE12 is offline
The tips I was talking about were Dropping you system to an 1ohm load, meaning the power you are drawing from your amp is taking on less of a resistance.
Basically you would configure your wires from the back of your subs were you would run the positive wire from one sub to the other and same with the ground.
You would have to have the dual connections in the back of the subs though.But when you do this you would only have 1 set of speaker wires running out of your box and simply bridge the connection to your amp where on the positive side of your amp you would use the positive channel for the hot wire, and vice versa on the negative side.
Down side good way to blow your amp if you have not used all of you LPF adjustments to ther full potential.
  #28
Old 03-25-2010, 07:27 PM
Matt99's Avatar
Matt99
Matt99 is offline
hmm ive had the same amp like over 6 years tied in 12v and not one problem. Im sure it will now go out tomorrow though
and ive got mine wired like you said. Thats how I was taught, I just have done it without knowing why
  #29
Old 03-25-2010, 07:36 PM
OICUDRIVE12
Well you have been doing it right in my opion. It has the cleanest look and best db hits on that setup.
With some correctly placed ports you can have a nice setup.
You sound like you have been in the spl game, you ever built a spl vehicle?
  #30
Old 03-25-2010, 08:05 PM
BlakeCP29's Avatar
BlakeCP29
yah my subs are running at 2 ohms right now. im just gonna keep it that way cuz its all the boom i need for now. when i get some more $$$ and feel like getting a new system, then i will do the 1 ohm thing...but my amp isnt 1 ohm stable so ill just plan on blowing it whenever i do that haha. i need a box now. im just gonna get 2 12" foxboxes when i get the chance since they dont have dual 12's that i could find. any adjustments besides raising the seats i would have to do?
Quick Reply: panel removal question, sub install
