3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Aftermarket with no drain plug, don't ask me why it doesn't have one. Wasn't there when I installed it in Florida when old one went. I didn't have a clamp to use so had to cut it.
This trick was presented by another member about a month ago. If your thermostat doesn't have a bleed hole you can push it open and use a asprin to hold it open so when you first install the thermostat it will allow the air/water to flow and purge the system when the engine is first started..
It's also preventative maintenance on guarding your truck from it having a heart attack
If those are you power steering lines then there is no drain plug there.
Yep, that's one of my PS lines, of course the other is a hose draining coolant. Aftermarket...that explains it I guess. What a PITA that is for you. Well, at least ya got it installed ok.
