260 cam for a 2003 dodge ram 1500?
Old Apr 13, 2010 | 04:18 AM
sparta531's Avatar
sparta531
Default 260 cam for a 2003 dodge ram 1500?
Hey guys was wondering where i could find a cheap 260 cam.I have a 2003 dodge ram 1500 quad cab that i want to upgrade a bit. Also what else am i going to need? Thanks
Old Apr 13, 2010 | 06:11 AM
RedTruck-VA's Avatar
RedTruck-VA
Welcome, sounds like you need to join the "Forgottens". There are many of us who would like to re-cam our 03's.
Old Apr 13, 2010 | 06:51 AM
AF_HEMI's Avatar
AF_HEMI
Why did you choose the 260?
Old Apr 13, 2010 | 01:24 PM
sparta531's Avatar
sparta531
Based off what every one was saying about the 6.1 cam. Not to mention i saw a you tube video of a truck taking off, after that i knew that was the one i wanted.
Old Apr 13, 2010 | 02:40 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
As far as parts go you will also need some 6.1 springs and pushrods. Then all the tools and fluids needed for the swap. Check out weed's diy on swapping a cam, it tells you everything you need to know.
Old Apr 13, 2010 | 02:54 PM
sparta531's Avatar
sparta531
Is there a site i can go to that has the entire kit?? So i don't have to find each part?
Old Apr 13, 2010 | 03:19 PM
AF_HEMI's Avatar
AF_HEMI
the 260 is still a very mild cam. if you really want performance, i think you'll be disappointed with the 260, especially after the multi-day install
Old Apr 13, 2010 | 04:20 PM
RedTruck-VA
Sparta,
Here is a link to the Forgotten club. https://dodgeforum.com/forum/dodgefo...tten-club.html
Plan carefully, order your parts and go for it.
Good luck..
Old Apr 13, 2010 | 05:01 PM
03MopaRamman's Avatar
03MopaRamman
I dunno Guys, the 260 from what I have heard talking to someone that has run both it and the 6.1 in his 03 liked it alot better than the 6.1 (I know wasn't my best choice either but better than stock). The 260 likes the Superchips and you can supposably run it with stock springs (But like Teach says I wouldn't just to be safe) Now remember no need to remove the heads or oil pan guys. I think the 03 tranny would also like the 5500 RPM peak as well. A good first Cam if you don't have many mods to start. Just my 2 cents. Maybe something for further discussion in the forgottens?
Old Apr 13, 2010 | 05:12 PM
Off_Road_Teacher
Here is a chart showing what types of gains you can expect over stock by installing a comp 260 (chart also has the gains for the 268 and 273). This is from an engine dyno and I believe the engine was also running headers.
