Transmission kicks out
Old Apr 20, 2010 | 09:14 PM
jrwhunting2500's Avatar
jrwhunting2500
Default Transmission kicks out
I have a 2003 Dodge Ram 2500 diesel and i have a annoying transmission or transmission related problem that no one can figure out. When i am driving the truck and romp on the throttle the tranny kicks out. It happens in any gear and even in lock up. The transmission is built up with suncoast converter and so on and i know its nothing internal but was wondering if it could be any sensors or cables. I have no idea and just want to fix the problem any help is much appreciated.
Old Apr 20, 2010 | 09:48 PM
rcman0056's Avatar
rcman0056
See if there is any play in your tranny cable that goes to your shift lever. It may be tittering between D and N. Have had mine kick out because the handle was not put into D all the way.
Old Apr 20, 2010 | 10:12 PM
hemiguy0302's Avatar
hemiguy0302
Yeah and mine dropped to 2nd on my one because I had it between gates. Can you describe the problem more? Does moving the gear lever help at all? Any weird noises? My guess is the cable just needs to be checked for binding or replaced.
Old Apr 21, 2010 | 08:30 AM
jrwhunting2500
The transmission shifts fine if you are not on the throttle, it goes through all the gears and shifts great. As soo as you put it down 3/4 or full throttle the tranny kicks out and doesn't allow power to the wheels, the rpms go up but there is no transfer in power to the tranny. Now it does this in overdrive when its locked i will be cruising at like 70 and get on it and it kicks in and out. The transmission was just gone through piece by piece and it is nothing in the transmission.
Old Apr 21, 2010 | 08:44 AM
rcman0056's Avatar
rcman0056
Put it in "1" and see if it slips out. If it does then I would guess the problem to be your tranny seeing as you had it worked on. Might be a bad TQ converter or internal tranny problem. Also When you floor it does it slip but will it reengage if you let the throttle off to 1/4 or 1/2. Although might be odd but your Rear diff could be stripped out or some other connection from your tranny to your wheels. The higher RPMs is what would make it slip.
Old Apr 21, 2010 | 04:34 PM
hemiguy0302
sounds like you are losing a pump or a converter. Have you been monitoring the trans temp?
Old Apr 22, 2010 | 08:34 AM
jrwhunting2500
The transmission does reengage as soon as you let off. I know its not the converter cause i put one in like a week ago. I put in a suncoast triple disc with a medium stall speed. The tranny guys says he does not know what could be causing it he tried putting stiffer springs in the valve body but it did not help at all. Some people tell me it might be the tps or kick down cable but im not sure how to tell. I have not been burning up fluid or the tranny is not running hot. I am running stacked chips but the tranny still does it when it is stock without them.
Old Apr 22, 2010 | 10:28 AM
meen green machine's Avatar
meen green machine
buddy of mine had the same problem and i believe they ended up redoing the whole transmission. you may want to contact sun coast as i have read they have had some problems. you may also want to try some other sites that specify the cummins and this transmission you may find alot more answers
Old Apr 22, 2010 | 12:34 PM
nim81's Avatar
nim81
i was having a problem similar to this and i adjusted my tv cable from the throttle body to the tranny and havnt had a problem since, not sure how the diesels are setup though, what tranny do you have?
