HELP!! trucks dead
Old May 8, 2010 | 12:08 PM
pontiac2k2's Avatar
pontiac2k2
Default HELP!! trucks dead
So my wife drove the truck home spitting and sputtering the other day, it died as she pulled it into the driveway. I assumed she had just ran it out of gas as I have had some problems with the guage reading correctly. I put gas in it and it wouldn't start. Threw the po300 multiple cylinder misfire code. Checked all the wires and connections and tried to start it again, I got it started gave it some gas a few times and heard an awful metal rattling noise so I shut it off. Pulled all the plugs and on the drivers side closest to the firewall the electrode was smashed into the plug. The engine will crank by hand to a certain point then will not go any further. Suggestions?? I'm getting ready to go pull the valve cover and head on that side to take a look, anyone want to guess??
Old May 8, 2010 | 05:05 PM
MikeHTally's Avatar
MikeHTally
Broken rod somehow? If the plug got swatted by the piston, the piston was trespassing, big time. Doesn't sound good. Good luck on this one.
Old May 8, 2010 | 05:23 PM
dirtydog's Avatar
dirtydog
Moderate User
Plug damage is never a good thing. I would NOT turn it over anymore! You need to have it looked at by a qualified mechanic.
Old May 8, 2010 | 06:19 PM
RedTruck-VA's Avatar
RedTruck-VA
Could be a dropped valve... You will know when you get the head off. What engine? Good luck..
Old May 8, 2010 | 07:49 PM
Gone Fishin's Avatar
Gone Fishin
I'd guess you spun a rod bearing. If its not under warranty, pull the oil pan and check the suspect cylinder. Either way, valve or bearing-----its done until its repaired.
If you continue trying to roll it over or fire it, you may do substantially more damage.
Pull the valve cover and check the valves for that cylinder, if you don't find something there, its most likely the bottom end.
Old May 8, 2010 | 10:40 PM
pontiac2k2's Avatar
pontiac2k2
I pulled the valve cover and have a broken valve spring on that cylinger for starters.. I'll try to pull the head tomorrow, I'm sure there is much more damage in there. luckily this is not my daily driver
Old May 8, 2010 | 10:44 PM
pontiac2k2's Avatar
pontiac2k2
Forgot to mention there was about a gallon and a half of antifreeze in the oil when I drained it, as well as oil tainted coolant in the radiator when I took it out.
Old May 8, 2010 | 11:26 PM
RedTruck-VA
Let's just hope it is a broken head, but it sounds bad. But on the other hand you can tell the wife, hey you broke my motor now I have to replace it. I smell a mod.
Old May 9, 2010 | 03:13 AM
wyseguy77's Avatar
wyseguy77
Always a bright side. Good luck.
