Catalytic Converter ?
A few months ago I had Pacesetter LT headers, Pacesetter Y-Pipe, Aero Turbine muffler, and a Magnaflow cat. put on my truck. All was fine for a week or two then the dreaded check engine light came on.... It's now been on for 2 months or so...forget the code #, but it's for cat efficiency. To make a long story somewhat short, my gas mileage has tanked and I was wondering if I could be using the "wrong" cat? I ordered the Magnaflow 94169 from Moe's and I should have realized from the time I received it, that it was about half the size of the stock cat. I've been searching around for other people having problems after doing LT's and haven't found anything related to what's happening to me. Any thoughts?
Truck is definitely running rich (I can smell it) no idea why its running so rich either...Had the SC performance tune on it, but decided to put it back to stock in hopes it would lean it out. Didn't do anything, I can still smell gas all the time. I think I need to have the PCM reflashed, because my RPM's drop at idle, to around 500 and the truck starts to shake a little. Could this cause me to be running so rich possibly? As for how I like the setup...I love it! It sounds awesome!
Trending Topics
Yeah, I'm only running a single cat (that's all my truck had stock) and a 180 T-stat. About the O2 sensor being in a "loop"..I brought the truck to a buddy that hooked up his scan tool and was watching the sensors while the truck was running. Apparently they pass the test, but they are fluctuating up and down at almost the exact same times (I'm not very knowledgeable about O2 sensors). I'll try rebooting the PCM later today after work and see if that helps any.
