3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Don't be so quick to think you don't have the factory LSD. Sometimes the factory one requires you to slightly tap the brake while accelerating. If that doesn't work then Ditto what every one else has said.
Actually 'Nitto, if he still has the factory LSD in his '04 it needs to come out of there ASAP anyway, IMO...
Absolutely. Most just don't realize that there is a time bomb in there if they don't know the little brake trick. A while ago someone thought they didn't have one in there so they assumed they were safe from the clips until they had there wife watch while applying the brake and gas at the same time on some gravel.
yes im very sorry guys, im in a joking mood, do not do that at all to your normal driving car/truck... i dont have posi when i power brake it take off hard but my baby will pull some rank donuts!! lol idk why but it will soo guess its all in how you drive it and know your truck for the most part
Or maybe check out a powertrax automatic locker half the money and the carrier doesnt have to be removed from the diff just the spider gears and pull the axles out a few inches and it installs where the spider gears used to reside. Ive had no issues with this setup for the street
