Cams... This is giving me a headache!!!!
Old Jun 13, 2010 | 06:41 PM
  #21
truckin151's Avatar
truckin151
Ordering from CompCams diretly the 268 is $417, ordering from Jegs is its $361.99 and ships Monday. Anyone else know a cheaper deal on it? If not Im gonna order it
Old Jun 13, 2010 | 06:43 PM
  #22
truckin151's Avatar
truckin151
Originally Posted by RubberFrog
6. springs/rods and you'll be good to go. And a tune.
Yeah I knew I was going to need the tune and springs/rods regardless of which one I went with. Just didn't know if the performance heads were needed or not (some of inertia's specifically say that performance heads are needed).
Old Jun 13, 2010 | 06:49 PM
  #23
RubberFrog's Avatar
RubberFrog
You'll do heads eventually, if you want to go fast.
Old Jun 13, 2010 | 07:03 PM
  #24
Off_Road_Teacher's Avatar
Off_Road_Teacher
A little cheaper here, $355 shipped. You get a free t-shirt too .
http://cgi.ebay.com/ebaymotors/COMP-...Q5fAccessories
Old Jun 13, 2010 | 07:16 PM
  #25
RubberFrog's Avatar
RubberFrog
stu grind of a 268
Old Jun 13, 2010 | 08:24 PM
  #26
truckin151's Avatar
truckin151
These COMP Cams Xtreme fuel injected camshafts are designed for late model applications. They are ground on a 113 degree lobe separation using faster-opening and more efficient ramp profiles. Xtreme camshafts are engineered for 1.6 ratio rocker arms and beehive valve springs, which provide a dramatic increase in torque and horsepower.
Pulled this info off of SummitRacing's page, I assume that the rocker arm ratio is based on the stock rocker arms, and the beehive can be replaced by the 6.1 springs/rods I got sitting here with no issues right?
Just want to be sure on this before I pull the trigger. I wasn't doing a lot of research into the compcams to start with so I got everything ready for the spartan to go in. Now I just want to be sure that its all still going to work together
Old Jun 13, 2010 | 08:26 PM
  #27
Maori's Avatar
Maori
Old Jun 13, 2010 | 08:27 PM
  #28
Maori's Avatar
Maori
No failures that i know of with the 6.1 springs/rods.
Old Jun 13, 2010 | 08:28 PM
  #29
Off_Road_Teacher
You will be fine with the 6.1 springs/rods.
Old Jun 13, 2010 | 08:33 PM
  #30
truckin151's Avatar
truckin151
And the rocker arm ratio is the same as stock correct?
