keeps shutting off??
Old 08-08-2010, 10:28 AM
red ram ridin's Avatar
red ram ridin
red ram ridin is offline
Default keeps shutting off??
My truck ran out of gas yesterday, as I was pulling into the gas station. Luckily I was able to coast to the pump. Had a little trouble after starting up again it shut off as I was leaving, and then as I got home it shut off as I was pulling in driveway, and then once as I was pulling into the gym. Always shuts off as im stopping it seems never cruising. Do you guys think that there is air in the gas lines? Occasionally the idle would drop when im sitting still as well. Is it ok to drive it or should I wait til the shop opens?
Old 08-08-2010, 10:33 AM
red ram ridin
Note: It did start up first try after pumping gas
Old 08-08-2010, 10:38 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
For some unknown reason, these trucks DO NOT respond well after running out of gas. I believe I read a while back where a guy had the same problem and re-set his PCM and it fixed the issue.
Old 08-08-2010, 10:39 AM
red ram ridin
I feel like maybe my IAC motor is failing because even before this event there were 2 occasions which my motor idle would drop at a stop light and rev back up or stay lower.
Old 08-08-2010, 10:40 AM
red ram ridin
Whats the PCM?
Old 08-08-2010, 10:44 AM
red ram ridin
I just looked into it more there was a post on if your engine revs up and down at a stop and thats what mine does... Not sure if that contributes to it turning off when im coming to a stop though but it could I guess.
Old 08-08-2010, 01:39 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
PCM = Power Control Module = AKA computer.
Look under the good and pull the PCM fuse from the fuse panel (maybe fuse #23) and set it set for a few minutes.
Old 08-08-2010, 04:02 PM
red ram ridin
ill try that when it stops pouring outside. Hopefully that will do the trick because its getting worse. Just drove to work and it shut off at the stop light and hardly ever idles right now. If thats not it ill check the IAC.
Old 08-08-2010, 04:52 PM
outcast's Avatar
outcast
outcast is offline
my truck did that and it was the battery was shorting out started a little slow and wouldnt idle right
Old 08-08-2010, 05:45 PM
red ram ridin
but wouldnt i see the battery dying on the dash gauge?
Quick Reply: keeps shutting off??
