engine experts needed!!!
Old 08-13-2010, 12:55 AM
pontiac2k2's Avatar
pontiac2k2
pontiac2k2 is offline
could a bad camshaft sensor cause this? The sensor is from the old engines timing cover?? Shouldn't it throw a code if it's bad?
  #22
Old 08-13-2010, 07:51 AM
truckin151's Avatar
truckin151
truckin151 is offline
If its the cam sensor it would throw a code, almost everything will throw a code or at least should.
Im stumped man, the last thing I think I would check would be the plugs and wires and just make sure that everything is correct and nothing was crossed anywhere.
  #23
Old 08-13-2010, 01:10 PM
freestyledude's Avatar
freestyledude
freestyledude is offline
Just to double check have you used the key trick to pull any codes?
  #24
Old 08-13-2010, 06:04 PM
pontiac2k2's Avatar
pontiac2k2
I have a scanner to pull codes but what's the key trick?
  #25
Old 08-13-2010, 08:48 PM
truckin151's Avatar
truckin151
cycle the key on/off/on/off/on (do it once more if it doesn't pop up, I always forget how many times you gotta cycle it, pretty sure its 3 times though) and it should pop up a code oe ----- where the OD is.
  #26
Old 08-13-2010, 10:57 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
I have seen bad cam and bad crank sensors throw the timing way off and either not start or backfire and carry on.
  #27
Old 08-13-2010, 11:51 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Not every model will give you the P'codes by cycling the key. Also on the hemi's if the valve timing or just one bad valve, will cause the engine to backfire and misfire. I have seen the plastic intake manifolds split in half.
  #28
Old 08-14-2010, 12:08 AM
pontiac2k2's Avatar
pontiac2k2
I picked up the cam sensor today and will be installing tomorrow
  #29
Old 08-14-2010, 10:32 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
That was my thought was valve timing but other than that or timing chain, IDK
  #30
Old 08-14-2010, 10:44 AM
pontiac2k2's Avatar
pontiac2k2
Installed the cam sensor... It didn't help anything, still having the same problems. While it was running I manually opened the throttle body a little and it ran great, not sure how to check to make sure that is funtioning properly??
Quick Reply: engine experts needed!!!
