3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Okay, well of course when Tim goes out of business, I start having problems soon after. I usually feel that I know alot about HIDs but this is starting to bother me
When I cut them on, one side will have a very dim flicker but I will cut them on/off three or four times and it will work. This started after unhooking my battery for two days. Bad ballast? Obviously not the bulb..what y'all think
You could always swap the ballast around. But I would also get my meter out and measure the resistance on the resistors he has on them and compare the numbers to the other side.
