Transmission Line Pressure Booster
Old Oct 1, 2010 | 11:36 AM
  #71
azlodaniel1's Avatar
azlodaniel1
Thanks Weed and OlDirtyJohn,
Couldnt have done it with out your knowledge and help.
I want to do some more testing to see if you can run the 2.2kohm and the 390ohm at the same time, without any issues.
Old Oct 3, 2010 | 02:35 AM
  #72
vincent714028's Avatar
vincent714028
Would a hair dryer provide sufficient heat to shrink heat shrink tubing for the wires?
Old Oct 3, 2010 | 09:26 AM
  #73
rengnath's Avatar
rengnath
A hair dryer may .... depending on how hot it really gets. You can just use a lighter; keep the flame away from the tubing so you dont burn it, and just use the heat. Always keep it moving until it shrinks no more, and then stop.
Old Oct 4, 2010 | 10:13 AM
  #74
weedahoe's Avatar
weedahoe
Hall of Fame Member
I use the flame from the lighter on mine but just keep it moving. So either way it can be done.
Old Oct 4, 2010 | 12:39 PM
  #75
runvs's Avatar
runvs
keep us updated i may try to run the 390 resistor on line 2 with my 2.2 already and see what ahppens
Old Oct 27, 2010 | 09:12 PM
  #76
kmill44's Avatar
kmill44
Default resistor
Im new here but i have been trying to decide if i wanted to give this a shot so today i made the plug to run the 2.2k ohm resistor on line 1 and 3 and noticed a slight difference just driving around so then i went ahead and added 350 ohms or resistance on line 2 at wot it shifts 2nd to 3rd at about 5600 rpms i was impessed at the differnce tomorrow i am goin to bump it up to 390 ohms i will post back up if there is a difference.
Old Oct 28, 2010 | 08:27 AM
  #77
weedahoe's Avatar
weedahoe
Hall of Fame Member
Make sure you reset your PCM for the best results.
Old Dec 22, 2010 | 10:06 PM
  #78
rangstng's Avatar
rangstng
I am planning on doing this on my truck and was looking for the one I can buy I would make one if I could find a place to buy the factory plugs because I dont want to cut the factory harness. Dose anyone know If you can buy them or not, also i have a 07 1500 5.7 hemi witch one would i use
Old Dec 23, 2010 | 07:58 AM
  #79
SLT8's Avatar
SLT8
any before and after speedo runs?
Old Dec 23, 2010 | 08:16 AM
  #80
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://www.sonnax.com/product-lines/...ion/parts/1785
