power window problem
Old Oct 17, 2010 | 07:25 PM
marky0304's Avatar
marky0304
Default power window problem
2004 QC, 1500 SLT, 5.7, 4x4 with power windows. The problem is this. I can operate all 4 windows both up and down from the drivers seat. The windows will not function from any other spot. Before you ask, yes I checked the window lock button, several times both ways. Any Ideas or solutions?
Old Oct 17, 2010 | 07:59 PM
Big_Wheel's Avatar
Big_Wheel
mine does this every once in a while..and all i have to do is unlock my doors and lock the p/w and then unlock again--- lol i still havent got around to solving the problem, its probably just a loose wire going to the drivers switch
Old Oct 17, 2010 | 08:50 PM
MikeHTally's Avatar
MikeHTally
Common issue. The driver's door switch module interrupts the signal to the other switches. Many folks have had reasonable luck by removing the door switch and cleaning the contacts.
Old Oct 17, 2010 | 09:44 PM
Denniss66's Avatar
Denniss66
i just finished taking the switch apart on my truck its pretty simple to do. the only hard part is getting the window switches off. i knew i should of took pics of what i did to mine cause lots of dodges with that window lock have that problem. all i did was take the window lock apart and bent the contacts in and stretched the spring out i bit so it pushes up hard enough to make the switch reach the contacts. i can take it apart tomorrow and do pics of it if you need.
Old Oct 18, 2010 | 08:11 AM
truegent81's Avatar
truegent81
Haha. Man I was having this same issue. I thought my new 03 I bought was flawless and I was letting the in laws check it out when they went to unroll the windows and it didn't work. I told them the lock was off and to go ahead. Still didn't roll down. But I'm glad to hear it is a simple fix. Now I just need to figure out how to put a soft buffer in between where the plastic controls make contact with the panel. There is a slight vibration and it makes an annoying noise with the radio on because it vibrates.
Old Oct 18, 2010 | 11:57 AM
MongoDV8's Avatar
MongoDV8
Originally Posted by Denniss66
the only hard part is getting the window switches off.can take it apart tomorrow and do pics of it if you need.
How do you get the switches off ? I tried to take my switch apart yesterday but stopped because I was afraid it would self destruct if I pried any harder.
Pics would be cool.
Old Oct 18, 2010 | 10:00 PM
truegent81's Avatar
truegent81
Any pics?
Old Oct 19, 2010 | 04:59 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you take the door skin off you can push the switch panel out from the bottom easier.
Old Oct 22, 2010 | 07:42 PM
truegent81's Avatar
truegent81
for some reason my switch panel already comes off real easy on driver side. anyway, would we need to pinch the metal pieces on all four doors? if this is the case, i would have to remove the entire back door panels since the switch is in the middle?! man...
Old Oct 22, 2010 | 09:07 PM
wills03's Avatar
wills03
I did the same thing with my wife on my 04 that I just bought a week ago. I am gonna have to try and take the switches out and clean the contacts if I am reading the posts right. I would rather do this than take it to the dealership and pay 50% of the cost to fix it. LOL.... I'm guessing the easiest way to get the switches out is to take the door panel off and cleaning them with alcohol?
