Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Sep 5, 2011 | 03:17 PM
  #261
dodge1hemi00's Avatar
dodge1hemi00
i have the same problem with my 07 the drivers side headlight only has a highbeam the passenger and fogs work fine and i put all the stock lights back in and they work fine
so what could be the problem
Old Sep 5, 2011 | 07:14 PM
  #262
dale.bricka@yahoo.com's Avatar
This is the issue i have been having. I finally got a pretty decent video of the issue and the resistors are on.
This is the link to the video.
http://www.youtube.com/watch?v=geWSGRmkGws
Old Sep 5, 2011 | 07:48 PM
  #263
sad_drake's Avatar
sad_drake
Originally Posted by Salt Life Ram
I'm having an issue with my HID's, I have an 07 and purchased and installed an HIDEXTRA (dual beam HID Bi-Xenon kit) about 8 months with no problems!
now all of a sudden only the high beams work??
I have an 07 with the same problem. I have had my HIDs for around 2 years with minimal issues that were easy fixes. Now I have no low beams. I have put in the stock lights and checked and re-checked everything. I have looked but found no fuses relating to headlights or even blown. I am actually debating on taking my truck to a local dealership unless there is another possible solution. I would be greatful and in debt to a solution. PLZZZ help
Old Sep 5, 2011 | 08:01 PM
  #264
weedahoe's Avatar
weedahoe
Hall of Fame Member
if the stock light work then i would look at a loose connection or bad connection somewhere. swap the ballasts from one side to the other and see if the problem stays or follows the ballast
all i see is a wall i think with light on it? what am i missing or supposed to be seeing?
if you have no low beams at all even with standard bulbs then it is likely the TIPM needs to be replaced. check with dirtydog on this for more info
Old Sep 5, 2011 | 08:35 PM
  #265
sad_drake's Avatar
sad_drake
in the video the light seems to almost "bounce" towards the top left of the light. mine would do the same sometimes as the bulbs were warming up. thanks for the info on the lights looks like i could be goin to the dealer after all
Old Sep 5, 2011 | 08:38 PM
  #266
The twitching of the light I can see it just fine through the video. The twitching is not from the camera as it was steady. Look closer and you will see. Maybe I am just picky but I would expect no jitter of no affect.
Old Sep 6, 2011 | 01:07 AM
  #267
They do that even after the truck has been running for a half hour like they are still trying to light or something
Old Sep 6, 2011 | 04:35 PM
  #268
Ben D.'s Avatar
Ben D.
dale... it's the kit that you have.. Either a defective bulb or ballast. I had a bulb do that on my truck with a cheaper kit and in my troubleshooting I swapped to a new bulb and it fixed the problem.
Old Sep 6, 2011 | 05:19 PM
  #269
Just a cheap kit then you suppose Ben. Where did you get your from and when I have an extra 100 dollars laying around I will buy a new set but I really dont want to run into the same problems. One more shot at it is about what I can take at the moment.
You have the list of components you have installed and yours are will the resistors as well.
Old Sep 6, 2011 | 07:03 PM
  #270
Ben D.'s Avatar
Ben D.
i got mine from
diodedynamics.com
but it might not be that your kit is cheap... defective parts happen.. I'd say swap ballasts side to side and see if the problem follows the ballast or bulb.. then contact your seller and get a new part.
