Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 30, 2011 | 10:10 AM
  #251
weedahoe's Avatar
weedahoe
Hall of Fame Member
you can buy bixenon harnesses off ebay for about 10 to 15 bucks. no need to rig and build one.
Old Aug 30, 2011 | 02:44 PM
  #252
dale.bricka@yahoo.com's Avatar
After searching the internet a while today I came a cross this page will these eliminate the twitching issue. Any thought guys.
http://store.ijdmtoy.com/Canbus-Deco...us_decoder.htm
Old Aug 30, 2011 | 03:29 PM
  #253
weedahoe's Avatar
weedahoe
Hall of Fame Member
Those are links of items that always pop up but are no different than the resistors we use to trick the FCM/PCM
Old Aug 30, 2011 | 08:18 PM
  #254
Salt Life Ram's Avatar
Salt Life Ram
I'm having an issue with my HID's, I have an 07 and purchased and installed an HIDEXTRA (dual beam HID Bi-Xenon kit) about 8 months with no problems!
now all of a sudden only the high beams work??
Old Aug 30, 2011 | 10:14 PM
  #255
weedahoe's Avatar
weedahoe
Hall of Fame Member
put the oem bulbs back in and test both low beams and high beams
Old Aug 31, 2011 | 08:22 AM
  #256
bandroidx's Avatar
bandroidx
Originally Posted by dale.bricka@yahoo.com
Has anyone tried the new CANBUS Ballast, if so did you have any issues and also has anyone tried to do wiring for both passenger and drivers side on thier own relay system
that is what i have the canbus digital bixenon from hidextra. it works just plugged in to the headlight system, no strobing or anything. just a bulb out coede on the dash. a relay with this system wont work thought unless u use resistors (see above)
Old Aug 31, 2011 | 10:02 AM
  #257
Now are you guys using the 35w or 55w with resistors? Also are they digital ballast or not. I am just looking for a new and fresh start.
Old Aug 31, 2011 | 01:34 PM
  #258
weedahoe's Avatar
weedahoe
Hall of Fame Member
mine are branded Flash Tech and was bought from Chad at Unique Coatings. they are 35w and not digital. i bought them about 3 or 4 yrs ago i guess. ive got 6ks in my heads and fogs
Old Sep 2, 2011 | 04:59 AM
  #259
bandroidx's Avatar
bandroidx
if 35 watt is enough then i think i will use them over 50 watts.
Also, instead of using the resistors, (i keep hearing how hot they can get sometimes) since i dont mind the bulb out light in the dash, i am going to power my relay from the parking lights as a trigger. i never use the parking lights w/o the headlights anyways.
Old Sep 2, 2011 | 09:09 PM
  #260
weedahoe's Avatar
weedahoe
Hall of Fame Member
you are failing to realize the reason for resistors are two-fold. first and foremost is to simulate oem bulbs. if you do that then you wont get a lamp out light
