Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Dec 23, 2012 | 11:53 AM
  #491
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by Gabriel Campos
I bought a Xenon Lightining system to replace the stock bulbs in my 2008 dodge ram 1500. After replace everything, did not work at all. NO LIGHT. All wires are connected and the only doubt I had is where to connect the red and black because on my truck wires shows black in the middle, white and blue in one side and white and green in the other side.I tried to switch back an forth those white wires and still did not work. Any help ?
Please post a link or picture of what you have exactly. Also, are you using a relayed wiring harness for your setup?
Old Dec 25, 2012 | 04:06 PM
  #492
Jordanmontero91's Avatar
Jordanmontero91
I need to know where can i buy the connector that connects tge factory headlight wiring the the controller for my hids for a 2000 grand caravan
Old Dec 25, 2012 | 05:09 PM
  #493
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you know what headlight socket number you have such as a 9006 then you can go to ebay and buy them. I recently bought two H4 sockets for the HID setup I'm doing on my bike
Old Dec 25, 2012 | 11:31 PM
  #494
Glenshadow's Avatar
Glenshadow
Originally Posted by usafjetdriver
Ok, I'm closer to tracking down why I'm still getting the LAMP OUT warning, but it's confusing.
The lights are working fine (still no high beams, but I'll tackle that later), but the LAMP OUT won't go away.
What I've found:
- The passenger side resistors are doing their job and getting hot to the touch
- The driver side resistors are ice cold *BUT* still completing a circuit! If I disconnect their ground (or +), the lights start strobing.
Any one have any ideas what's going on? With the harness I have, the resistors are wired into the blue plug that clips into the OEM 9007 socket.
So it's weird that they are completing a circuit but not getting warm, and apparently not replicating the factory amount of resistance.
Well I would say there is a possibility that the resistor is defective in some way. Have you tried measuring the ohms on it and the other to compare ? Also maybe compare both and see if the wiring is exactly the same between them. (make sure somehow wiring wasn't wrong and is bypassing the resistor)
At this point is where you would probably want to get a spare set of resistors, as well as double check them like I had mentioned if they are similar Ebay type. Gold heat sinks and the wires are crimped, not actually soldered like they should be.
Are you saying both lights work fine even though one resistor is stone cold ? That to me would indicate a bad resistor set on one side which would give you the lamp out. Can you switch known good resistor (mark it somehow) to other side ? Does it continue to get hot as normal or does it now stay stone cold ?
I love my lights don't get me wrong... but if I woulda know they were going to be such a headache.. I would not have made the switch. Hopefully all the bugs are ironed out of mine, and I do love them.. but I would almost try to shave an angry bears *** than have to go through it all over again ! hahaha
Old Dec 31, 2012 | 09:13 PM
  #495
Mesto's Avatar
Mesto
so which kit is recommended?! Max Vision I cant seem to find there website..
Old Dec 31, 2012 | 09:15 PM
  #496
weedahoe's Avatar
weedahoe
Hall of Fame Member
Any kit will work as long as you know how they work and why. All that info is back on Page 1
Old Jan 1, 2013 | 10:42 PM
  #497
Hemi coll's Avatar
Hemi coll
Default Hid resistor issue
I'm new to this forum and have been looking at this thread and I ordered a resistor harness recommended on weedahoe's page. I got the new harness and it has 2 plugs on the harness but I only have one plug, my old bulb plug, so I have no idea where the other resistor plug goes?? Any suggestions are greatly appreciated. The kit is a 55watt h13 10k DDM tuning kit
Old Jan 1, 2013 | 10:50 PM
  #498
weedahoe's Avatar
weedahoe
Hall of Fame Member
Post pics or a link to the resistors you bought
Old Jan 2, 2013 | 11:41 AM
  #499
Hemi coll's Avatar
Hemi coll
Default Resistor
Old Jan 2, 2013 | 05:26 PM
  #500
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ok, so one if them connects to the drivers side headlight plug and then the HID harness plugs into it
The other one plugs into the pass side headlight plug and nothing gets plugged into the other end of it. Just zip tie it up and out of the way along with anything else during your install
