Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Feb 22, 2016 | 11:04 PM
  #861
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by rambradley
I just installed an hid kit from Xenonhid on my 2013 ram. All I did was the low beam for now. I got the best ballast they make. It's a 55w ac canbus ballast. I also got the relay harness too. Ok so since my drivers side is hooked to the relay harness and my passenger side is hooked to nothing I'm getting a lamp out on my passenger side. My main issue is I'm getting a clicking sound when the lights are on but only while I'm driving. If I put my foot on the brake it goes away. If I come to a stop it stops. So there's no way of me getting out to diagnose where the noise is coming from because it doesn't start doing it until I start driving again. If I turn the fog lights off it gets worse but still stops at the same points as described. The lights work fine. Just those two issues. Would love some help in the matter. Thank you
Since you have nothing connected to the other side, add the load resistors to mimic the place of the bulb. Refer to the first page for more info and instructions
Old Feb 23, 2016 | 06:31 AM
  #862
rambradley's Avatar
rambradley
What about the clicking noise? Will this go away once I add the resistors? Thanks
Old Feb 23, 2016 | 07:16 AM
  #863
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes, the clicking will stop and the lights will work
Old Feb 23, 2016 | 07:23 AM
  #864
rambradley's Avatar
rambradley
Awesome. Thank you. One more question please. Is there a way to disable the DRL?
Old Feb 23, 2016 | 08:18 AM
  #865
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not that I am aware of but here is the US we do not have that enabled so again, not that I am aware of.
Old Feb 29, 2016 | 06:15 PM
  #866
rambradley's Avatar
rambradley
I installed two morimoto transistors on my low beam circuits. I did this Saturday. It did fine Saturday night and Sunday night. Did fine this morning too. Got in truck to go home from work and got the low beam headlight out warning message. I hooked the launch up to it and I've got a B162E-15 code which is right low beam control-circuit short to battery or open.
Old Mar 1, 2016 | 07:36 PM
  #867
weedahoe's Avatar
weedahoe
Hall of Fame Member
You said low beam but said nothing about the high beam. Being the headlights are dual filament with both high and low beam, this means you need load resistors on both meaning 4 total
Old Mar 11, 2016 | 11:23 AM
  #868
rambradley's Avatar
rambradley
My high and low beams are SEPERATE. They aren't one bulb. Anyway I found my issue with that. One of the resistors came unsoldered inside of the case so I had to resolder the wire. My next problem is I went ahead and bought a kit for my fog. They automatically **** the fog light circuit down and I had codes saying both fog light circuits were short to ground. I thought they weren't can bus? Anyway I didn't buy a harness with this set so I'll buy a harness and hopefully will work. Just hope I don't have to install resistors on my fogs.
Old Mar 11, 2016 | 12:13 PM
  #869
rambradley's Avatar
rambradley
Ok so just found out that starting 2013 the fog lights are now wired into the canbus system. It will not turn on a bulb out message but will require canbus ballasts and highly recommended to install a harness too.
Old May 23, 2016 | 03:30 AM
  #870
Dereck Jackson's Avatar
Dereck Jackson
Question HID lights wont work on brights
I just hooked up my hid lights in my 07.dodge ram 1500. When my truck is turned off and I turn my low and hi on they work. But when I turn my truck on the low beams work and when I switch to my hi beams the flash 3 times and shut off. How do I fix this??? Please help......
