Cracked Dash/ Leaf springs/heater coil
Old 01-10-2011, 04:30 AM
TXDodgegirl03's Avatar
TXDodgegirl03
TXDodgegirl03 is offline
Default Cracked Dash/ Leaf springs/heater coil
Does anyone know where to get a new dash not a cover for less than $300 or more in some cases and is it hard to change out the leaf springs (atleast i think this is why my truck is squeaking) GRRRRR ready for a new truck! Plus my heater is not working one side of the heater coil gets warm the other is cold, could this just be a plug? no water is leaking or anything.
thanks!
Old 01-10-2011, 04:33 AM
96magnumram's Avatar
96magnumram
96magnumram is offline
Leaf springs are fairly simple to change as long as you have jack stands to support the truck and a floor jack to support the differential. As for the heater core, when is the last time you flushed your cooling system?
Old 01-10-2011, 04:46 AM
TXDodgegirl03
well had to put a new radiator in not sure if he flushed it then, i doubt it. Think he just charged it so NEVER would be my guess.
Old 01-10-2011, 04:56 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Try pick 'n pulls (salvage yards) for the dash. You may have to go in and take it out of a truck yourself, but you'll save a bunch.
If the leafs are not bad (sagging) try soaking them down pretty heavy with a penetrating lubricant to quiet them down.
As for the heat, as stated, try flushing the system...
Old 01-10-2011, 05:20 AM
96magnumram
Yeah, you should be flushing your cooling system at least once a year. Even though engine coolant has some corrosion inhibitors in it, it does break down over time, leading to a plugged up rad or heater core, ESPECIALLY if anybody has run any of those "bandaid" type sealants through it. If you want to do it yourself, try the Prestone Super cleaner.
Old 01-10-2011, 07:17 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yeah, before I would replace the the leaf packs I would pull the pins out of the shackles and grease them really good. Chances are, thats there yous squeaking is coming from. Mine used to do the same.
Old 01-11-2011, 03:37 AM
TXDodgegirl03
Thanks for the help ya'll, trying to save a lil $$$ but my POS keeps giving me more headaches! Hope some of these ideas work.
kAci
Old 01-11-2011, 08:05 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Well like Hammer said, if you spray the pins in the shackles with WD40 or PB Blaster or other oil and the noise goes away (temp) then you know thats your issue.
Quick Reply: Cracked Dash/ Leaf springs/heater coil
