3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
so i did the on off key trick to get codes and those are the numbers that came up any help on this reason i was doing this is because my heater blower only works when i wiggle the key now it wnd even work anymore any help thank you
IDK where you are getting those codes from either. But do yourself a favor and go by an auto parts store and let them connect their ODBII scanner to the truck and tell you the codes.
If your inside blower motor only works when you wiggle the key then you need a new ignition switch.
