Performance suggestions
Old Mar 20, 2011 | 10:59 AM
Hemifan21's Avatar
Hemifan21
Arrow Performance suggestions
Im looking to upgrade my 05 1500 5.7. I already have K&N CAI, Superchips 93 tune, and the previous own had installed a dual cat-back exhaust, but Im hoping I could put a fairly agressive cam into it and plans are already in place to install TTI headers and 3" dual exhaust with an x-pipe for balancing. Any advice would be greatly appreciated. Just trying to get as much info as possible.
Old Mar 20, 2011 | 12:23 PM
lxman1's Avatar
lxman1
Site Moderator
Do you have a std cab, quadcab, 2wd or 4wd? 4.56 gears will geive you a good boost in performance without costing much mpg.
Old Mar 20, 2011 | 06:12 PM
Hemifan21's Avatar
Hemifan21
quad cab 4x4
Old Mar 20, 2011 | 07:00 PM
freestyledude's Avatar
freestyledude
for a really aggressive cam you'll need a chip like the Diablo. If you don't go too crazy I think you can get by with a regular chip? (correct me if I'm wrong)
Gears, line pressure booster, efan are all common mods.
Old Mar 20, 2011 | 09:00 PM
Hemifan21's Avatar
Hemifan21
im not looking for something really crazy. just a solid mid-range and bit choppier idle
Old Mar 21, 2011 | 01:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you want a good cam with a really nice lope and low end power you will need to get custom tuned. Where are you located?
Cam - 400-450
Tuner - 250-350
Tuning - 250-400
(16) 6.1 exhaust springs - 65
6.1 push rods - 11
cam bolt - 3
crank bolt - 1
wide band - 150
head gaskets and bolts - 100
7 qrts oil plus filter
1 qrt of ATF4
then you either need to pay someone to do it or do it yourself. Special tools you need are a damper puller and a valve spring tool.
Ive got some youtube vids of my truck and cam at www.youtube.com/weedahoe
Old Mar 21, 2011 | 10:59 PM
Hemifan21's Avatar
Hemifan21
im attending school in Chatt. TN but i live in northern TN. could i do custom tuning myself?
Old Mar 21, 2011 | 11:35 PM
chefred112's Avatar
chefred112
not with diablo, you have to have a cmr tuner make you tunes... or spend $2500 and get the cmr software and blow your truck up yourself... ive seen someone do that with sct and the pro racer software...
Old Mar 22, 2011 | 07:25 AM
Hemifan21's Avatar
Hemifan21
then where would i go to have get the pcm tuned?
Old Mar 22, 2011 | 09:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Bean's Diesel Perfor
210 Rollin Coal Lane
WOODBURY Tennessee, 37190
(615) 563-7800
Injected Engineering
3605 Kennesaw N. Industrial Pkwy. STE. D
Kennesaw GA, 30144
678-449-6871
Kurgan Motosports
5450 Technology Pkwy
Braselton GA, 30517
815-669-7223
Mountain Muscle Cars
2750 Cosby Highway
COSBY TN, 37722
(423) 532-7091
