Some Front Tire Wiggle(Cause Vibration?)
Hey all I had notice some acceleration vibration at lower speeds. Since then I have check all the rear end etc. Today I jacked up my front end. Once in the air I found that both my front tires are wiggling a little bit. Seems that both are wiggling in all direction. Front to back/top to bottom. I have about 80,000 miles on the and harder than most with it unless you count oil field and gas workers.
What would cause wiggle in all directions? Could this be the cause of my vibration during acceleration? I am going back out in a bit to have someone wiggle it while I look. I am not sure if it is tie rods, wheel bearings, ball joints etc. What process should I go through to check each?
on
Rule of thumb is side/side play is indicative of tie rod ends, up/down play is ball joints BUT the thing is gonna need an alignment when you replace either and you are going thru the same procedure basically for either one.
If the truck has enough mileage on it that one goes, you can bet the other is going to go before too long. Replace both at the same time, hell a pair of tie rod ends aren't much more expensive than an alignment, so it'd be stupid to do ball joints and an alignment just to turn around and have to do tie rod ends and an alignment in a couple of months.
Just happened to me this week. 2006 Ram 1500 with 60k
I thought the aforementioned replies... until it was discovered my back tire was "warping". I had the tire swapped out and I have no wobble any more. I was very surprised as I would have sworn the wobble was coming from the front end.
I have heard Dodge's stock offering on tires were poor during these years.
Trending Topics
check out both www.rockauto.com and www.ebay.com for parts prices online as they seem to be the best.
on
I read a review done by a top auto magazine on the BFG Traction T/A tire (which were the ones that came stock on my Grand Cherokee) and the rating they gave them differentiated between the OE dealer model and the aftermarket model and they gave the OE one a 1 out of 5 rating and the aftermarket one a 4 out of 5 rating!
I think that's just downright criminal!!!
