Transmission Test Port Location Help/ Trans Guage Install
Old Jul 22, 2005 | 03:35 AM
glwilliams58's Avatar
glwilliams58
Default Transmission Test Port Location Help/ Trans Guage Install
I am installing a trans temp gauge and understand from other forums that the sending unit can be easily installed in a transmission test port. Here is an excellent discription of the process done on a 2500 with the 48RE transmission.
http://www.dodgetruckowners.org/dto/...er=asc&start=0
I have the 04 1500 5.7 Hemi with the 5-45 RFE transmission and I can not locate anything that resembles a test port as shown in these photos. If anyone has done this before and can provide some direction or provide a link to some technical diagrams of this 5-45RE I would greatly appreciate it.[sm=confused06.gif]
Thanks.
Old Jul 23, 2005 | 06:23 AM
tazassape's Avatar
tazassape
Default RE: Transmission Test Port Location Help/ Trans Guage Install
Try this site HTC.com I just saw a posting on that site about transmission temp gauges. Hope this helps.
Old Jul 23, 2005 | 07:10 PM
glwilliams58
Which site? HTC.com = Goldman Sachs, a leading global investment banking firm.
Is there another site you had in mind?
Thanks.
Old Jul 23, 2005 | 09:56 PM
tazassape's Avatar
tazassape
Try www.hemitruckclub.com and find the forum section. You will find any and all info you need about your HEMI. Sorry about the confusion.
Old Jul 24, 2005 | 03:16 AM
glwilliams58
That was a great piece of advice thanks.
Check this thread for some pretty visual input on this issue.
http://hemitruckclub.infopop.cc/grou...163#8270031163
No definitive answers yet, but a lot of good input on the tranny and the test ports. As you can see, I am still figuring out if it makes any difference with test port to use, or if there is a risk of using the wrong one.
Thanks alot.
gw
Old Jul 24, 2005 | 05:37 AM
tazassape's Avatar
tazassape
Glad to help. I just found those guys (and gals) a couple of weeks ago and was amazed at the amount of info available.
Old Jul 25, 2005 | 09:39 PM
glwilliams58
taz,
Just coming full circle with you. Thanks for the help on this. With that diagram I was able to confirm through a trusted tranny shop here that contacted the Dodge tech line thise evening, that the #3 TCC apply is the place to put the temp sending unit. That port has contant oil and is the most accurate reading.
Thanks again.
gw
Old Jul 26, 2005 | 03:26 AM
Avanti's Avatar
Avanti
One of the simpler sensor installs is to replace the drain-plug with it, assuming the tranny has a plug.
Old Jul 26, 2005 | 04:29 PM
glwilliams58
There is no drain plug on this one, but the test ports are real easy to get to.
Unfortunately, I just discovered the test ports are too small for the sending unit that came with the guage. It looks to be 1/4" port and the guage came with a 3/8" fitting. I'm checking to see if there is a smaller sending unit available. Otherwise I need to find a different location for it.
gw
