EGR hemi question
Old Feb 13, 2012 | 11:50 PM
FrenicX's Avatar
FrenicX
Default EGR hemi question
I asked about 2005 hemi motors a week or so ago, now I'm back with another question about gen III hemis in general.
I have heard that some hemis have an EGR in one of the cylinder heads. Does anyone know what years and/or models have this? And if it's not in the head, where else would it be? Or do some motors not have an EGR at all?
Thanks in advance guys.
Old Feb 14, 2012 | 12:00 AM
PRADO's Avatar
PRADO
if it has an EGR valve itll b bolted in front of the passenger side cylinder head. itll have a tube that goes to the back side of the throttle body
Old Feb 14, 2012 | 12:23 AM
FrenicX's Avatar
FrenicX
Thanks man.
I don't have a hemi yet, I'm in the planning stages for a project and trying to get as much info as possible. Most of the engines I've looked at are just online so it's hard to inspect. My main concern is PCM compatibility, are there any sensors involved in an EGR setup?
Do the truck hemis have them, or is it a car thing.. or vice versa? Is it more of a year related thing? or just random lol.
So I can choose a motor with EGR or without? Which is the better setup?
thanks again to all you motorheads out there, any info is appreciated.
Old Feb 14, 2012 | 12:32 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
03s dont have EGRs but 04+ does unless its a 2500. No 2500 has them
A replacement EGR is about $40
Old Feb 14, 2012 | 12:49 AM
PRADO's Avatar
PRADO
The egr sensor is on the egr itself. i wouldnt use one if i had the choice.
Old Feb 14, 2012 | 01:02 AM
FrenicX's Avatar
FrenicX
ok, so I found a good pic of one, it will be easier to spot a motor with or without one now. can it damage the cats without an egr?
I will try to find a motor without one, but if push comes to shove, I can use a billet deletion plate I found on shophemi.com. I will need a custom SCT tune for this project anyways, so I think i will be fine without the egr. I honestly don't know of my 4.7 has one, I will have to check..
thanks again for letting me pick your brains.
Old Feb 15, 2012 | 01:56 AM
FrenicX's Avatar
FrenicX
Well I just looked, found an EGR valve on the back of my 4.7.. and also checked my local laws for engine swaps in newer vehicles. I will have to have an engine with EGR to be "legal" since my truck is vin'd for one.
Old Feb 15, 2012 | 02:11 AM
NoLimitzR1's Avatar
NoLimitzR1
Just pull it off plug it and get a custom tune to negate the effects the pcm does to your air fuel ratio
