IAT resistor mod
Old Feb 28, 2012 | 10:36 AM
gHEMImorePower's Avatar
gHEMImorePower
Question IAT resistor mod
How can I make that iat resistor mod on a 2006 hemi 5.7?
Old Feb 28, 2012 | 10:48 AM
HammerZ71's Avatar
HammerZ71
Why don't you just install a 180* thermostat and get the added benefit of the engine actually running 15* cooler than just fooling the PCM into thinking it is???
Old Feb 28, 2012 | 07:08 PM
KasperR34's Avatar
KasperR34
What if we did both?
Old Feb 28, 2012 | 07:23 PM
HammerZ71's Avatar
HammerZ71
Too rich IMO...
Old Feb 28, 2012 | 07:25 PM
KasperR34's Avatar
KasperR34
Noted. Please Check your PM's Hammer
Old Feb 28, 2012 | 09:24 PM
John  M's Avatar
John M
I did the IAT mod not for the fuel (which gets tuned out at part throttle) but for the extra timing. I use it with only 93 octane and it seems to be pretty happy. The extra fuel just helps ward off knock at WOT. I have zero concern about MPGs.
Old Feb 29, 2012 | 11:10 PM
Plainbroke's Avatar
Plainbroke
IAT resistor wire bumps timing too?
Old Feb 29, 2012 | 11:30 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got a homemade power wire on mine and a 180 stat but my truck is also custom tuned
Here is a How To BTW
http://www.youtube.com/watch?v=qUjAI9ZGXkY
Old Mar 1, 2012 | 10:01 AM
1wide7's Avatar
1wide7
Correct me if im wrong but doesn't the power wire trick the ecu into thinking its colder out? which allows the ecu to advance the timing?
So advanced timing should cause a lean condition not a rich one
Old Mar 1, 2012 | 10:31 AM
John  M's Avatar
John M
Colder air is denser so it would run leaner but the ECU sprays more fuel to go with the (perceived) greater airflow. Thus, you get more timing and run a little richer at the same time. It's not great for gas mileage but it's the ticket for more power.
Ideally we'd like to have direct control over all of this but for years like the 03 we're stuck with manipulating the sensors to get the computer to do what we want.
