Headers
Old Mar 7, 2012 | 10:39 PM
JustINploided's Avatar
JustINploided
Default Headers
I want to get some headers i have new exhaust on it and just not complete right was told i should get some shorties but idk the difference between the longer ones or short ones I have 2wd Ram 5.7l hemi 1500. Any advice or thought please input. Also brands
Old Mar 9, 2012 | 09:13 PM
robinsonfam1's Avatar
robinsonfam1
look at FAQ section.
shorties vs LTs depends on what you want from your truck?
Old Mar 9, 2012 | 09:22 PM
SLT8's Avatar
SLT8
shorties should be direct bolt on to current setup. LT's..not so much.
Old Mar 10, 2012 | 03:25 PM
JustINploided
well isnt it LT you just get more Torque out of it? plus I would have to do more pipe work i believe as to the Shortys being kinda of a snap on situation. I want better performance but im not towing a airliner most i tow/pull i could use my stock everything and be fine. Plus im not mudding
Old Mar 10, 2012 | 03:34 PM
JustINploided
just performance thats all i want
Old Mar 10, 2012 | 05:44 PM
robinsonfam1
then LT's with custom system behind it. x pipe it or siamese and go!
then cam and intake with ported TB.
Old Mar 11, 2012 | 12:54 AM
JustINploided
Would I need to take it to a body shop for them to do that or what? i was more or less looking to be able to DIYS but better performance is my goal so thats what matters.
Old Mar 11, 2012 | 09:42 AM
SLT8's Avatar
SLT8
Performance then look into Long Tubes. DIY is up to you. Prob' want to research more on what it entails. If a shop then look into a exhaust shop vs a body shop.
Old Mar 11, 2012 | 11:07 AM
robinsonfam1
dont take this wrong but..........this is prolly over top of a a standard DIY project. installing the headers is a diy job, but after that youre talking about welding pipe, bending it, etc....
to get it right i would take it to a shop that can do exactly what you want. that also means you might have to make some calls and face to face with ppl and looking at cars before you go the the closest exhaust shop just cuz theyre closer and cheaper.
hope this helps...just my 2 cents
Old Mar 12, 2012 | 12:24 AM
JustINploided
I was told shortys wouldnt really need work but LT would so I would def take my truck to a shop if i was doing LT i am not that mechanically inclined.
