Special tool to change shocks?
Old 07-13-2012, 03:42 PM
MeAndMyHemi's Avatar
MeAndMyHemi
MeAndMyHemi is offline
Default Special tool to change shocks?
My Chilton's manual says I need a special tool to change the front shocks. IS that true and if so, what is it?
Thanks
Old 07-13-2012, 05:08 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
First you need a shredder to use on the Chilton's manual. Is yours 4x4?
Old 07-13-2012, 11:09 PM
Arctodus's Avatar
Arctodus
Arctodus is offline
Not true. You can take the springs and shocks out without any special tools.
Old 07-13-2012, 11:17 PM
hemi4109's Avatar
hemi4109
hemi4109 is offline
That's odd... a couple of wrenches for the bottom bolt and the top nut is all that was required on my truck. Maybe I should have read the manual... Maybe there was a way to have a cold beer sooner.
Old 07-13-2012, 11:49 PM
froy's Avatar
froy
froy is offline
could be talking about a spring compressor.
Old 07-14-2012, 12:20 AM
Jareski's Avatar
Jareski
Jareski is offline
There's always a way to have a cold beer sooner.
Last edited by Jareski; 07-14-2012 at 12:20 AM. Reason: My keyboard made a mistake.. :)
Old 07-14-2012, 07:41 AM
MikeHTally's Avatar
MikeHTally
That's what I was thinking. The '08 4x2s aren't struts, are they?
Old 07-14-2012, 09:36 AM
Arctodus's Avatar
Arctodus
Arctodus is offline
You usually only need a spring compressor if your putting in a lift kit or leveling kit. I had to use one when I put my leveling kit in even though I have a solid axle.
Old 07-14-2012, 09:50 AM
dakotatrevor's Avatar
dakotatrevor
dakotatrevor is offline
You'll need a spring compressor to take the strut apart. In his truck, you dont need a spring compressor if you are putting in a leveling kit (spacers). But you'll need one if you're doing leveling struts.
Edit - I'm just assuming it's 4x4...I suppose I shouldn't assume
Old 07-14-2012, 10:42 AM
MeAndMyHemi
Its 2WD.......
Quick Reply: Special tool to change shocks?
