Etc problems!
Old Sep 1, 2012 | 05:41 PM
  #21
Dmac25's Avatar
Dmac25
Which ones the map and which ones the iat ?
Old Sep 1, 2012 | 06:04 PM
  #22
Dead2Fall's Avatar
Dead2Fall
Map is on the tb, iat is on the intake tube itself. Doubt they both went bad at the same exact time... But hey ya never know...
Old Sep 3, 2012 | 11:01 AM
  #23
Dmac25's Avatar
Dmac25
Well I replaced those sensors and cleaned the intake and the etc light went of and it ran great. Still have the CEL but not too worried about that. I appreciate all if yalls help and I'm sure I'll be back!
Old Sep 3, 2012 | 12:34 PM
  #24
willdikem66's Avatar
willdikem66
Map is on the intake maifold not the TB?
Old Sep 4, 2012 | 08:18 AM
  #25
Northern Goat's Avatar
Northern Goat
Originally Posted by MoparPaul
You can try re-calibrating the TPS
With the key on (engine not running) Slowly depress the pedal to the floor in an span of 30 secs, then release slowly over 30 secs... Its worth a shot anyways...
That is fo the diesel engine not the Hemi's. I have seen that at least 500 times and its not correct info. I checked with Dodge mechanic here and he confirmed it.
Old Sep 4, 2012 | 08:23 AM
  #26
Northern Goat
I was going to say the same thing. Nothing you can change on 2004 TB Its all internal.
Old Sep 4, 2012 | 02:42 PM
  #27
willdikem66
Yeah the map is a the front of the intake right in between the alternator and A/C
Old Sep 5, 2012 | 10:32 AM
  #28
dsullivan22's Avatar
dsullivan22
Hey guys, sorry to hi-jack but I have the same random misfire code. I just changed my plugs with the OEM Champion Coppers. Are all those sensors the next step? I am going to clean the Throttle Body next. I had the battery off during the whole plug change, so I don't think doing that step again will help but its easy so I might try it. Any other suggestions? When I start it sometimes, I will drive for about 1 minute and it starts to basically die. It runs super rough, then my light comes on flashing and I lose power, so I pull over and turn it off. Turn it back on, no light and it runs great. Any help would be great
Old Sep 5, 2012 | 10:44 AM
  #29
kenneymc's Avatar
kenneymc
I would clean TB. Random misfire? Is it always same cylinder or different ones? Could be the coil for that cylinder.
Old Sep 5, 2012 | 10:52 AM
  #30
dsullivan22
Doesn't tell me a cylinder...just random misfire, that's the problem. It's just weird that it only happens sometimes, the night does not stay on, and it just loses power, then I turn it off and back on, and it's good to go. That's why I'm wondering if it is a sensor or computer or something electrical.
