Truck just failed inspection...advice needed
Old 09-13-2012, 04:26 AM
Bigboytoys's Avatar
Bigboytoys
Bigboytoys is offline
Default Truck just failed inspection...advice needed
Ok, so I got a letter in the mail yesterday that my two year registration was up. So I took it this morning thinking, if any minor thing failed, I would have time to fix it (I have 60 days till the registration is up). I wasn't expecting the things he did fail me for though...
UNSAT 1: E-brake pulling too hard to the left...Brand new brakes on all 4 corners done by the Dodge Dealership.
UNSAT 2: Worn shocks....Not leaking, but he said they need to be replaced..I don't know how he knows as there was no test to them up and down wise...just a machine that shakes it left and right.
UNSAT 3:Oil leak near the front of the motor.....Didn't notice any oil leak when I changed the oil last month....
Any advice on fixes?
Old 09-13-2012, 05:26 AM
Bigboytoys's Avatar
Bigboytoys
So I priced out shocks....For about 50-70 dollars more I can get the Rough Country 3 inch lift....oh the wifey will be happy about that (sarcastic laugh)
Old 09-13-2012, 06:42 AM
loflyer2's Avatar
loflyer2
loflyer2 is offline
on oil leak, check the torque on the bolts attaching the oil pan to the block. These bolts lose torque easily.
Old 09-13-2012, 06:45 AM
Bigboytoys's Avatar
Bigboytoys
what should they be torqued to?
Old 09-13-2012, 07:44 AM
ewing111's Avatar
ewing111
ewing111 is offline
check in the service manual, all torque specs are there.
Old 09-13-2012, 07:46 AM
Bigboytoys's Avatar
Bigboytoys
I would, but I don't have one....
Old 09-13-2012, 08:44 AM
team_realtree's Avatar
team_realtree
team_realtree is offline
You can download a free copy in the DIY section.
Old 09-13-2012, 09:03 AM
kenneymc's Avatar
kenneymc
kenneymc is offline
Or look up weedaho, he has links to the manuals in his signature.
Old 09-13-2012, 09:40 AM
04HemiGreg's Avatar
04HemiGreg
04HemiGreg is offline
If the brakes were just done, go back and see if they will adjust. The shocks are an easy and obvious fix - just replace them (i am happy with my rough countries). On the oil leak, they couldnt give you a more precise location than "near the front of the motor"? Cant fix it until you know where it is.
Old 09-13-2012, 10:41 AM
willdikem66's Avatar
willdikem66
willdikem66 is offline
Dang and i thought emissions was the devil down here in Texas but it seems the put yalls trucks through everything far and in between.
How is your E Brake pulling to the left?
Quick Reply: Truck just failed inspection...advice needed
