2004 dodge ram 4.7 blown motor
Old 10-03-2012, 06:15 PM
Gbrum123's Avatar
Gbrum123
Gbrum123 is offline
Default 2004 dodge ram 4.7 blown motor
I got an 04 ram I recently blew up
Should I buy a new motor or get this one rebuilt??
Old 10-03-2012, 06:27 PM
willdikem66's Avatar
willdikem66
willdikem66 is offline
Either way its the same risk.
By "New" what do you mean. New to you or Brand New?
I couldnt tell which way is cheaper
Old 10-03-2012, 06:34 PM
stewie01's Avatar
stewie01
stewie01 is offline
Probably need to weigh cost & warranty of each and see which works out the best..
How'd you blow yours?
Old 10-03-2012, 07:46 PM
Gbrum123's Avatar
Gbrum123
Gbrum123 is offline
By new I mean remanufactured.
But thanks
And I sunk it like a clown but it happens
Old 10-03-2012, 07:48 PM
Gbrum123's Avatar
Gbrum123
Gbrum123 is offline
If I rebuilt it I would like to get a little bit of work done but I can't find anyone that can do anything.
Any ideas?
Old 10-03-2012, 08:13 PM
stewie01's Avatar
stewie01
stewie01 is offline
Either find a shop and have yours rebuilt or buy a new or used one. Simple. Rebuild may be costly depending on what's wrong with yours, brand new one will be expensive but will have some kind of warranty, used one probably cheap but limited warranty and it is used, never know what you're getting...
Old 10-04-2012, 09:26 AM
willdikem66
Like Stewie said a new one would be best because of its warranty but that will be the most expensive route for sure.
If you rebuilt yours it could run for a while longer but no easy mind with out a warranty, but this is def the cheapiest route
Old 10-04-2012, 01:39 PM
Gbrum123's Avatar
Gbrum123
Gbrum123 is offline
It only had 70,000 miles on it is why I was thinking rebuild. But I slung six rods and may have a cracked block anyways.
Old 10-04-2012, 02:47 PM
willdikem66
Well obvisuly if its cracked no go lol... but if its not a rebuild wouldnt be bad
Old 10-04-2012, 03:47 PM
stewie01's Avatar
stewie01
stewie01 is offline
Details would be greatly appreciated as to how you slung 6 rods... If you choose to have yours rebuilt you won't know what it will cost until a mechanic tears it down to see how bad it is...
Quick Reply: 2004 dodge ram 4.7 blown motor
