How much should it cost for two new tires?
Old 10-15-2012, 08:38 PM
CodeBlox's Avatar
CodeBlox
CodeBlox is offline
Default How much should it cost for two new tires?
My two front tires have lost a lot of tread and need to be replaced. Is it reasonable to assume I need an alignment done as well? I was quoted about around 460 dollars for the tires and 120 dollars for the alignment.
Old 10-15-2012, 09:08 PM
kenneymc's Avatar
kenneymc
kenneymc is offline
That all depends on the type and size of the tire. Also if 2 or 4 wheel alignment. Sounds high to me for 2 wheel alignment.
Old 10-15-2012, 09:14 PM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
Definitely on the high side. The alignment is even on the high end. I've never paid more than 75 for an alignment
Old 10-16-2012, 12:02 AM
sabin420's Avatar
sabin420
sabin420 is offline
265/70/17 Firestone A/T
400 or less for 2 tires and front alignment. Their is no adjustment to align the rear so you should pay $60 at most for an alignment. And about 160 per tire.
Old 10-16-2012, 12:49 AM
Nate_sorenson's Avatar
Nate_sorenson
Nate_sorenson is offline
also your wheel bearings may be going bad in either side on the front, having the side to side wobble bad bearings develop eats tires bad, ask me how i know. from chrysler bearings for me where 140 ea oe replacement. good luck hope it doesnt hurt your wallet too bad
Old 10-16-2012, 07:34 AM
08HEMI1500's Avatar
08HEMI1500
275/60R20 Sumitomo's cost me 500 for two but I later found out that I got ripped off and that they were a terrible tire.
Old 10-16-2012, 07:48 AM
mike54's Avatar
mike54
mike54 is offline
4 cooper discovery a/t 265/70-17 Load Range E tires for my truck was just over 1025.00
alignment was 79.00
Old 10-16-2012, 04:46 PM
CodeBlox's Avatar
CodeBlox
CodeBlox is offline
So there is no need for a four wheel alignment? Would a "front wheel" alignment be sufficient for having the front two tires replaced?
Old 10-16-2012, 06:12 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
try tirerack.com for the tire price, then price out the alignment separately
Old 10-16-2012, 07:08 PM
sabin420's Avatar
sabin420
sabin420 is offline
YES oij
Quick Reply: How much should it cost for two new tires?
