Please help!!!! Driving me nuts
Old Oct 23, 2012 | 04:31 PM
  #21
Izero's Avatar
Izero
no idea why it would change b/c of outside temp. but give it a shot and wait till summer...?
Old Oct 23, 2012 | 04:36 PM
  #22
Wilson01960196's Avatar
Wilson01960196
im not sure but it does..my buddy said its bc of a bad ground somewhere that current travels better through wires when its cold and not hot
Old Oct 23, 2012 | 04:39 PM
  #23
Izero's Avatar
Izero
it would have to be like over 120 or below -30 Degrees to affect current like that...
Might just be a bad connection period.....
Old Oct 23, 2012 | 04:43 PM
  #24
Wilson01960196
Idk i never had any problems with it starting or anything ill clean it after dinner and let u kno
Old Oct 23, 2012 | 04:44 PM
  #25
Izero's Avatar
Izero
Check the other grounds too... could be any of them....
Old Oct 23, 2012 | 04:54 PM
  #26
Wilson01960196
The ones on tge frame and the bottom of the engine?
Old Oct 23, 2012 | 04:56 PM
  #27
Wilson01960196
Is there anything that i could spray or something on the one on the engine till i have time to let it sit longer so its not hot when i stick my hand up in there haha
Old Oct 23, 2012 | 06:19 PM
  #28
Wilson01960196
I cleaned the ground on the post,frame and the engine and still no fix..any other ideas lol
Old Oct 24, 2012 | 07:51 AM
  #29
DodgeCares's Avatar
DodgeCares
I jus looked and noticed my ground that goes on my battert terminal is really crusty and white on tge end could that effect the ground ur talking bout..there are other grounds that go to the framr by the front wheel and another looks like it goes the the botom of the engine behine the power steerong resevior...on wire was laying against the case and it had a little crack in it so i wrapped it in electrical tape..the wire was hot ehere it was touching from where i had jus driven it
The only case I could find that may possibly be related to the issue says this:
There have been a few cases with wiring issues in Engine compartment on right side of vehicle near the PCM where the harness rubs against the Air Conditioning line. If this is noted to be the cause repair the harness drive the vehicle and recheck for any codes.
That is the only documentation I could find related to erratic speedo operation.
Old Oct 24, 2012 | 09:35 AM
  #30
Wilson01960196
Ill check the harness..would tye ac line somehow mept tge harness?
