2007 Ram 2500 Heavy Duty Transmission
Old Oct 26, 2014 | 09:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by walkereod
Is the valve itself on the torque coverter cooler where the cooler line screws in?
Old style Mopar filters had drainback problems. New ones are revised. This is the filter that looks like an oil filter mounted to the front portion of the transmission. It's the return filter. Easily changed.
Common symptoms: Delayed and harsh engagement.
Old Oct 27, 2014 | 12:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
The 68RFE, 65RFE, 45RFE and 545RFE do not have any band adjustments. You do have two transmission filters. The transmission that has band adjustments are the 42/44RE,46RE,47RE and the 48RE transmissions. Send me the last 9 of the vin and I'll be able to tell you which transmission you have by the build sheet and I could also send you the sheet too. They is also a AS68RC transmission for the 6.7 diesel too.
Old Feb 12, 2015 | 09:21 PM
TEX25's Avatar
TEX25
Default Build sheet for 2007 Dodge Ram 1500
Can I send my vin# for a build sheet
Originally Posted by DodgeCACares
Walkereod,
If you'd like to PM me your VIN#, I can send you your vehicle's buildsheet, which will be a list of the options the Ram came equipped with from factory. It will have the transmission information I believe you are looking for.
Old Feb 17, 2015 | 01:50 PM
SmokinJoe02's Avatar
SmokinJoe02
http://www.dodge.com/webselfservice/...ull&category=U
SJ03
