3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok guys I need help BADDDD I recently put in a new stereo system into my 04 dodge ram 4.7 and everything was working fine but then I had to pull the fuse running to the battery so I could finish the install and I heard a little poping sound! I didn't think nothing at the time so I put everything back together and when I went to go check the radio out again it wouldn't turn on! Also on top of that the turn signals don't work unless you have the truck completely turned on! What could be my problem?
I've tried that I pulled every fuse thats linked to those and every other thats not and no blown fuse anywhere! Now my door lock switch won't work as well!
Welcome to DF
I would use a 12 volt test light or a DVOM to check the fuses. I will move you post to the 3rd gen ram section for you and this way you'll get more response.
